The router said interface atm 0 is invalid.
miaozhixu
As i am a newbie, i read the BBA configuration guide, and try some commands in this guide.
When i enter the "interface atm 0" command in global configure mode, it said "Invalid input detacted at '^' marker.
Hm, the router is 1941 without adsl wic, is that the problem? No adsl wic no atm interface?
mfurnival
Level 4
Level 4
Yes, that is correct. Do a "show diag" and it will tell you which modules you have installed (if any).
mfurnival
Level 4
Level 4
Thanks for your help.
I do think I should got a ADSL WIC, maybe EHWIC-VA-DSL-A is suitable.
