Throughput del equipo IR1101
Hola.
Buenas tardes, alguien sabe Cual es throughput del equipo IR1101
pieterh
is this the information you are looking for ?
Cellular modules
Table 7.        LTE (3GPP Category 4) modules available with the IR1101
Theoretical download and upload speeds3
150 and 50 Mbps
150 and 50 Mbps
from: Cisco Catalyst IR1101 Rugged Series Router Data Sheet - Cisco
Gracias Pieterh por los comentarios, pero lo que ando buscando es el rendimiento del equipo cuando se conecta via LAN/WAN.
pieterh
according to this post such information is available but limited access -> you need to contact Cisco or your Cisco partner
nipun043  Cisco Employee
‎01-12-2023 09:08 PM
The router has 4 Fast ethernet ports and a 2 x 1G ports - so upto 2G throughput ( an advantage license is required to support the same )
Please see the TDM deck at salesconnect -
https://salesconnect.cisco.com/#/content-detail/a31da387-b292-4fec-83d1-5ad869422727
Muchas gracias Pieterh por la respuesta.
Saludos,
Jaime
