too many IP routing processes
error00002021
i have 3925 router and when i want to add new eigrp i get massage
too many IP routing processes . Could not create the router process
how can i solve this problem? how you thing if i upgrade ram 1 gb to 2 gb it solve problem ?
7 Replies 7
Deepak Kumar
We noticed the same behaviour on the Cisco ASA. When you try to add more than 1 eigrp process, you will get a message "Too many IP routing processes for this routing protocol. ERROR: Unable to create router process"
Its (your router) supports just <> instance of EIGRP process and that is as per design.
Please share "Show Version" output.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Francesco Molino
How many EIGRP process do you have running already?
What version and IOS feature do you have?
You're limited to 30 process EIGRP if I recall correctly.
Can you share your actual EIGRP config please?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi all  its show version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 16-Nov-10 01:48 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
DEA-VPN-ROUTER uptime is 12 weeks, 4 days, 20 hours, 36 minutes
System returned to ROM by error - a Software forced crash, PC 0x4A59B38 at 11:26:23 UTC Mon Sep 18 2017
System restarted at 09:06:11 UTC Wed Aug 22 2018
System image file is "flash0:c3900-universalk9-mz.SPA.151-3.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 999424K/49152K bytes of memory.
Processor board ID FGL16221184
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C3900-SPE100/K9 FOC16216VYY
Technology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Evaluation securityk9
uc None None None
data None None None
I have 24 eigrp 5 ospf  and 1 bgp  process
I need to check but i have 30 in mind as limit.
Can you share your config to see if there's a way we can tweak it a bit?
Let me take one in lab and test and come back to you.
Francesco
I confirm it's 30. The number i had in mind was the correct one.
Francesco
gaston.benitez
Hi.
As Francesco says, there is a limit of 30 processes.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_eigrp/configuration/15-mt/ire-15-mt-book/ire-enhanced-igrp.html
It seems that you are only allowed to have 30 processes, but this ammount is the sum of any other protocol thay may be running int the box also.
For example, here I have OSPF previsouly configured with two neighbors
R5#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
233.233.233.233 1 FULL/DR 00:00:36 192.168.35.3 Ethernet1/2
234.234.234.234 1 FULL/DR 00:00:32 192.168.45.4 Ethernet1/1
Lab#
If I try to create EIGRP processes, I can only create 28, because I have already occupied 2 of the available processes with OSPF
Lab#sh run | i eigrp
router eigrp 1
router eigrp 2
router eigrp 3
router eigrp 4
router eigrp 5
router eigrp 6
router eigrp 7
router eigrp 8
router eigrp 9
router eigrp 10
router eigrp 11
router eigrp 12
router eigrp 13
router eigrp 14
router eigrp 15
router eigrp 16
router eigrp 17
router eigrp 18
router eigrp 19
router eigrp 20
router eigrp 21
router eigrp 22
router eigrp 23
router eigrp 24
router eigrp 25
router eigrp 26
router eigrp 27
router eigrp 28
Lab#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Lab(config)#router eigrp 29
Lab(config)#
Now, if I try to enable any other protocol, I won´t be able to do it also, because of this limit
Lab(config)#router bgp 2323
Lab(config)#
BR
Gaston
