tools to increase network latency
yuhuiyao
All,
Is there any command on cisco router/switch/FW to add latency? Or is there a freeware running on a dual NIC windows box to add network latency?
Currently our application is running at 3ms delay environment, we want to see if it can support 10ms.
Giuseppe Larosa
Hello Yuhui,
I used some years ago a tool from shunra to emulate a satellite link with a PC with two NICs
http://www.shunra.com/free-trials.php
other possible choices exist on the net
for example
http://www.download32.com/wan-emulator-i37489.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello Yuhui,
for example
Hope to help
Giuseppe
exonetinf1nity
Always used IPERF, brilliant little tool. There is also a GUI based version called JPERF thats run's on Java.
Recommend them both.
http://iperf.sourceforge.net/
http://code.google.com/p/xjperf/
have a look at Wanem .. its an open source software and very easy to setup
http://wanem.sourceforge.net/
Narayan
