Will adding a switch help prevent WAN failover?
Desmond Smith
Please see the attached design for my dilema.
Desmond
vmiller
Level 7
Level 7
Why not just remove the HSRP config?
Thanks vmiller for responding!
My current setup does not include the switch that is in the diagram and currently if I lose (hardware failure) the primary 2911 router,  Hsrp will fail over to the secondary 2911 and also the 2nd Wan link, a good basic backup solution. I have two separate paths and that works fine but I dont want to fail over to Link 2 just because the primary 2911 is gone, I want to add a switch to the mix and if that primary 2911 fails I want it to then use the secondary 2911 to get to London but still using Link 1 to get back to the USA.
Is that scenario possible with just adding a switch between the comm element and the primary 2911 router?
Thanks again,
Desmond
Hi Desmond
I don't think you need switch in betweeen  primary WAN router, better to  remove HSRP and do static routing on WAN routers to route traffic.
