Track router command support for 1800 router
bapatsubodh
We are using 1841 router for point to point connectivity. We are configuring a failover for these thwo links. we need to use track command to track interfaces , so that if one fails we can route the traffic to another link. Our current IOS dont support this command , which IOS for 1841 will support this command.
Thanks in advance
subodh
royalblues
Level 10
Level 10
I think any 12.4 IOS with advance ip servcies feature set should support this
Use feature navigator for help
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Narayan
paolo bevilacqua
If you own all the routers involved, why not use a regular routing protocol instead. It's easier than configure "tracking".
Hope this helps,pleaserate postif it does!
