Traffic shaping - excessive drops?
sketterman
I am shaping my outbound router (2921) link to 50Mbs.  I have my QOS policy nested inside my shaping policy and I have noticed (what I think) is a high amount of packet drops in one of my queues.
Below is the output of 2 show policy-map interface g0/0 run back to back.  As you can see I lost around 21 packets in just a few seconds, yet my link is only using around 7Mbs.  My counters were cleared around 3 hours before I took this sample.  I have my 2 QOS policies listed after the output.  Any ideas why I am seeing all these packet drops?  My QoS understanding isn't exactly expert level yet, but it seems like something isn't working correctly.  Any tips would be appreciated.  Thanks in advance.
SAMPLE 1
GigabitEthernet0/0
  Service-policy output: SHAPE
    Class-map: class-default (match-any)
      31573394 packets, 23655469220 bytes
      30 second offered rate 7131000 bps, drop rate 13000 bps
      Match: any
      Queueing
      queue limit 256 packets
      (queue depth/total drops/no-buffer drops) 0/55237/0
      (pkts output/bytes output) 31518160/23588134456
      shape (average) cir 50000000, bc 200000, be 200000
      target shape rate 50000000
      Service-policy : WAN_QOS
        queue stats for all priority classes:
          queue limit 64 packets
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 120258/23706082
        Class-map: EF (match-all)
          120258 packets, 23706082 bytes
          30 second offered rate 0 bps, drop rate 0 bps
          Match:  dscp ef (46)
          Priority: 25% (12500 kbps), burst bytes 312500, b/w exceed drops: 0
        Class-map: AF41 (match-any)
          20181 packets, 2770959 bytes
          30 second offered rate 2000 bps, drop rate 0 bps
          Match:  dscp af41 (34)
            30 second rate 2000 bps
          Match: access-group 120
            0 packets, 0 bytes
            30 second rate 0 bps
          Queueing
          (pkts output/bytes output) 20181/2770959
          bandwidth 40% (20000 kbps)
          QoS Set
            dscp af41
              Packets marked 20181
        Class-map: AF21 (match-all)
          28562372 packets, 22381305435 bytes
          30 second offered rate 4721000 bps, drop rate 13000 bps
          Match:  dscp af21 (18)
          Queueing
          (queue depth/total drops/no-buffer drops) 0/55091/0
          (pkts output/bytes output) 28507286/22314221299
          bandwidth 34% (17000 kbps)
          2870584 packets, 1247686802 bytes
          30 second offered rate 2410000 bps, drop rate 0 bps
          Match: any
          (queue depth/total drops/no-buffer drops) 0/146/0
          (pkts output/bytes output) 2870438/1247436290
          QoS Set
            dscp default
              Packets marked 2869359
            Exp-weight-constant: 9 (1/512)
            Mean queue depth: 0 packets
            class     Transmitted       Random drop      Tail drop          Minimum        Maximum     Mark
                      pkts/bytes     pkts/bytes       pkts/bytes          thresh         thresh     prob
            0         2870438/1247436290    134/64490         12/984               20            40  1/10
            1               0/0               0/0              0/0                 22            40  1/10
            2               0/0               0/0              0/0                 24            40  1/10
            3               0/0               0/0              0/0                 26            40  1/10
            4               0/0               0/0              0/0                 28            40  1/10
            5               0/0               0/0              0/0                 30            40  1/10
            6               0/0               0/0              0/0                 32            40  1/10
            7               0/0               0/0              0/0                 34            40  1/10
SAMPLE 2
GigabitEthernet0/0
      31589736 packets, 23665225208 bytes
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/55258/0
      (pkts output/bytes output) 31534478/23597868640
          Match:  dscp ef (46)
          20185 packets, 2771873 bytes
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 20185/2771873
          QoS Set
            dscp af41
              Packets marked 20185
          28576958 packets, 22389554081 bytes
          Queueing
          (queue depth/total drops/no-buffer drops) 0/55112/0
          (pkts output/bytes output) 28521846/22322447962
          2872335 packets, 1249193172 bytes
          Match: any
          (pkts output/bytes output) 2872189/1248942723
          QoS Set
            dscp default
              Packets marked 2871109
            0         2872189/1248942723    134/64490         12/984               20            40  1/10
POLICY MAPS
show policy-map
  Policy Map WAN_QOS
    Class EF
      priority 25 (%)
    Class AF41
      bandwidth 40 (%)
      set dscp af41
    Class AF21
      bandwidth 34 (%)
    Class class-default
      set ip dscp default
      queue-limit 256 packets
       packet-based wred, exponential weight 9
      class    min-threshold    max-threshold    mark-probablity
      0       -                -                1/10
      1       -                -                1/10
      2       -                -                1/10
      3       -                -                1/10
      4       -                -                1/10
      5       -                -                1/10
      6       -                -                1/10
      7       -                -                1/10
  Policy Map SHAPE
    Class class-default
      Average Rate Traffic Shaping
      cir 50000000 (bps)
      service-policy WAN_QOS
Edison Ortiz
The drops seem to be happening with Class AF21. What type of traffic matches such DSCP value in your network?
You may have to increase the queue-limit under the class to something greater than 64 until the drops stop.
I don't think the shaper is causing the issue but if you want to isolate, you can apply the child policy-map to the interface and see if drops continue.
Edison
Edison Ortiz
Edison
I am putting the majority of my business WAN traffic in AF21 and setting my internet and a few bandwidth hogging servers in class-default.  I increased my queue-limit on my AF21 class to 256 and I have already lost 2715 packets in 15 minutes.
I guess I dont understand why a drop-rate is being applied when the link isn't full, or the queue isn't even hitting it's minimum bandwidth limit of 17Mbs.  Should I maybe increase my Bc value to something higher than the default 4ms?
---EDIT---
After the initial loss of packets, packet loss slowed down to almost nothing, so increasing the queue limit seems to have helped.
Packets that match that class will be placed in queues before they are dequeued. If the numbers of queues aren't enough, you will get packet drops. This behavior will occur even if you aren't reaching the maximum available throughput of the link and often seen under bursty traffic conditions.
As you stated, the situation has been resolved so please mark the thread accordingly.
Edison
