Traffic Shaping
jasongr33nway
Level 2
Level 2
I am trying to add a few shaping classification to an auto QoS policy-map and it is not working. I can see the matching packets for each class-map but the shaping is not happening.
ROPS-M0-A2-2-4500X-V(config-pmap)#do sh policy-map AutoQos-4.0-Output-Policy
  Policy Map AutoQos-4.0-Output-Policy
    Class AutoQos-4.0-Scavenger-Queue
      bandwidth remaining 1 (%)
    Class AutoQos-4.0-Priority-Queue
      priority
     police cir percent 30 bc 33 ms
       conform-action transmit
       exceed-action drop
    Class AutoQos-4.0-Control-Mgmt-Queue
      bandwidth remaining 10 (%)
    Class AutoQos-4.0-Multimedia-Conf-Queue
    Class AutoQos-4.0-Multimedia-Stream-Queue
    Class AutoQos-4.0-Trans-Data-Queue
      dbl
    Class AutoQos-4.0-Bulk-Data-Queue
      bandwidth remaining 4 (%)
      dbl
    Class Shape_Test
    Class Shape-10M
    Class Shape-20M
    Class class-default
      bandwidth remaining 25 (%)
      dbl
ROPS-M0-A2-2-4500X-V(config-pmap)#class Shape_Test
ROPS-M0-A2-2-4500X-V(config-pmap-c)#shape average 1500000
ROPS-M0-A2-2-4500X-VSS#sh policy-map int t 1/2/7
Service-policy output: AutoQos-4.0-Output-Policy
 Class-map: Shape_Test (match-any)
      54977717 packets
      Match: access-group 101
        54977717 packets
I wasn't sure if this policing on the output Auto QoS policy map would be an issue
Class-map: AutoQos-4.0-Priority-Queue (match-any)
      509160419 packets
      Match: cos  5
        138348028 packets
      Match:  dscp ef (46)
        303733728 packets
      Match:  dscp cs5 (40)
        9315 packets
      Match:  dscp cs4 (32)
        67069348 packets
      Priority: Strict, b/w exceed drops: 383
      police:
          cir 30 %, bc 33
          cir 30000000 bps, bc 123750 bytes
        conformed 123213236182 bytes; actions:
          transmit
        exceeded 4410471 bytes; actions:
          drop
        conformed 762000 bps, exceeded 0000 bps
8 Replies 8
Cisco Freak
Level 9
Level 9
Can you please try a nested service policy-map like this one:
policy-map SHAPING-100Mb
class class-default
shape average 100000000
service-policy AutoQos-4.0-Output-Policy
interface <WAN interface>
service-policy output SHAPING-100Mb
Does not let me.
ROPS-M0-A2-2-4500X-V(config-pmap-c)#serv
ROPS-M0-A2-2-4500X-V(config-pmap-c)#service-policy AutoQos-4.0-Output-Policy
% Invalid input detected at '^' marker.
ROPS-M0-A2-2-4500X-V(config-pmap-c)#?
Policy-map class configuration commands:
  bandwidth    Bandwidth
  dbl          Dynamic buffer limiting
  exit         Exit from class action configuration mode
  no           Negate or set default values of a command
  police       Police
  priority     Strict Scheduling Priority for this Class
  queue-limit  Queue Max Threshold for Tail Drop
  set          Set QoS values
  shape        Traffic Shaping
What device is this one? Can you please post a 'sh version' output.
4500X L3 Switch.
ROPS-M0-A2-2-4500X-VSS#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500e-UNIVERSALK9-M), Version 03.07.03.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 14-Jan-16 10:32 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG11
ROPS-M0-A2-2-4500X-VSS uptime is 37 weeks, 5 days, 18 hours, 57 minutes
Uptime for this control processor is 37 weeks, 5 days, 17 hours, 6 minutes
System returned to ROM by SSO Switchover
System restarted at 22:53:02 EDT Thu Sep 15 2016
System image file is "bootflash:cat4500e-universalk9.SPA.03.07.03.E.152-3.E3.bin"
Jawa Revision 2, Winter Revision 0x0.0x41
Last reload reason: issu~
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-C4500X-16'
    License Level: entservices   Type: Permanent
    Next reboot license Level: entservices
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE194705KZ
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
14 Virtual Ethernet interfaces
48 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Georg Pauwen
can you post post the output of 'show auto qos' ? The shaping needs to be configured in the parent policy map...
Strange....
ROPS-M0-A2-2-4500X-VSS#sh auto qos
AutoQoS not enabled on any interface
ROPS-M0-A2-2-4500X-VSS#sh auto qos int t 1/2/7
TenGigabitEthernet1/2/7
AutoQoS is disabled
There are two Policy-maps on the int inbound and outbound
ROPS-M0-A2-2-4500X-VSS#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ROPS-M0-A2-2-4500X-V(config)#policy
ROPS-M0-A2-2-4500X-V(config)#policy-map AutoQos-4.0-Output-Policy
ROPS-M0-A2-2-4500X-VSS#sh run | sec AutoQos-4.0-Output-Policy
class AutoQos-4.0-Scavenger-Queue
  bandwidth remaining percent 1
 class AutoQos-4.0-Priority-Queue
  priority
class AutoQos-4.0-Control-Mgmt-Queue
  bandwidth remaining percent 10
 class AutoQos-4.0-Multimedia-Conf-Queue
 class AutoQos-4.0-Multimedia-Stream-Queue
 class AutoQos-4.0-Trans-Data-Queue
    dbl
class AutoQos-4.0-Bulk-Data-Queue
  bandwidth remaining percent 4
    dbl
class Shape_Test
class Shape-10M
class Shape-20M
class class-default
  bandwidth remaining percent 25
    dbl
service-policy output AutoQos-4.0-Output-Policy
interface TenGigabitEthernet1/2/7
 auto qos
Do you have that configured ?
ROPS-M0-A2-2-4500X-V(config)#do sh policy-map int t 1/2/7
  Service-policy input: AutoQos-4.0-Input-Policy
    Class-map: AutoQos-4.0-VoIP (match-any)
      2792949194 packets
      Match:  dscp ef (46)
        2792680114 packets, 0 bytes
        30 second rate 0 bps
      Match: cos  5
        269080 packets, 0 bytes
    Class-map: AutoQos-4.0-Broadcast-Vid (match-all)
      264267 packets
    Class-map: AutoQos-4.0-Realtime-Interact (match-all)
      123250183 packets
    Class-map: AutoQos-4.0-Network-Ctrl (match-all)
      17878 packets
      Match:  dscp cs7 (56)
    Class-map: AutoQos-4.0-Internetwork-Ctrl (match-all)
      40267172 packets
      Match:  dscp cs6 (48)
    Class-map: AutoQos-4.0-Signaling (match-any)
      128156204 packets
      Match:  dscp cs3 (24)
        98943092 packets, 0 bytes
      Match: cos  3
        29213131 packets, 0 bytes
    Class-map: AutoQos-4.0-Network-Mgmt (match-all)
      7940118 packets
      Match:  dscp cs2 (16)
    Class-map: AutoQos-4.0-Multimedia-Conf (match-any)
      164139781 packets
      Match:  dscp af41 (34)
        162763865 packets, 0 bytes
      Match:  dscp af42 (36)
        1367070 packets, 0 bytes
      Match:  dscp af43 (38)
        8846 packets, 0 bytes
    Class-map: AutoQos-4.0-Multimedia-Stream (match-any)
      24384973 packets
      Match:  dscp af31 (26)
        17503151 packets, 0 bytes
      Match:  dscp af32 (28)
        6878718 packets, 0 bytes
      Match:  dscp af33 (30)
        3104 packets, 0 bytes
    Class-map: AutoQos-4.0-Transaction-Data (match-any)
      3015830585 packets
      Match:  dscp af21 (18)
        3014372004 packets, 0 bytes
      Match:  dscp af22 (20)
        1284968 packets, 0 bytes
      Match:  dscp af23 (22)
        173613 packets, 0 bytes
    Class-map: AutoQos-4.0-Bulk-Data (match-any)
      175399330 packets
      Match:  dscp af11 (10)
        170647343 packets, 0 bytes
      Match:  dscp af12 (12)
        9913 packets, 0 bytes
      Match:  dscp af13 (14)
        4742074 packets, 0 bytes
    Class-map: AutoQos-4.0-Scavenger (match-all)
      8065462966 packets
      Match:  dscp cs1 (8)
    Class-map: class-default (match-any)
      51316384957 packets
      Match: any
    queue stats for all priority classes:
      Queueing
      queue limit 3040 packets
      (queue depth/total drops) 0/383
      (bytes output) 126216457624
    Class-map: AutoQos-4.0-Scavenger-Queue (match-any)
      73436683 packets
      Match:  dscp cs1 (8)
        72754630 packets
      Match: cos  1
        0 packets
      Match: access-group name AutoQos-4.0-ACL-Scavenger
        682053 packets
      Queueing
      (queue depth/total drops) 0/1271
      (bytes output) 36821357680
      bandwidth remaining 1%
      520520013 packets
      Match: cos  5
        141678302 packets
      Match:  dscp ef (46)
        310430768 packets
        10055 packets
        68400888 packets
      police:
          cir 30 %, bc 33
        conformed 125878483064 bytes; actions:
          transmit
          drop
        conformed 1167000 bps, exceeded 0000 bps
    Class-map: AutoQos-4.0-Control-Mgmt-Queue (match-any)
      32420789 packets
      Match: cos  3
        21266597 packets
        4543 packets
        5614263 packets
        347362 packets
        3152061 packets
      Match: access-group name AutoQos-4.0-ACL-Signaling
        2035963 packets
      Queueing
      (bytes output) 12595807891
      bandwidth remaining 10%
    Class-map: AutoQos-4.0-Multimedia-Conf-Queue (match-any)
      159516194 packets
      Match: cos  4
        47645740 packets
        262861 packets
        295523 packets
        4697 packets
      Match: access-group name AutoQos-4.0-ACL-Multimedia-Conf
        111307373 packets
      Queueing
      (queue depth/total drops) 0/89
      (bytes output) 46116853980
    Class-map: AutoQos-4.0-Multimedia-Stream-Queue (match-any)
      5672876 packets
        5438926 packets
        232361 packets
        1589 packets
      Queueing
      (queue depth/total drops) 0/2
      (bytes output) 799672403
    Class-map: AutoQos-4.0-Trans-Data-Queue (match-any)
      16002012 packets
      Match: cos  2
        3037784 packets
        893450 packets
        23361 packets
        2824 packets
      Match: access-group name AutoQos-4.0-ACL-Transactional-Data
        12044593 packets
      Queueing
      (queue depth/total drops) 0/0
      (bytes output) 2287879500
      dbl
          Probabilistic Drops: 0 Packets
          Belligerent Flow Drops: 0 Packets
    Class-map: AutoQos-4.0-Bulk-Data-Queue (match-any)
      86152385 packets
      Match: cos  1
        0 packets
        82127979 packets
        576 packets
        43876 packets
      Match: access-group name AutoQos-4.0-ACL-Bulk-Data
        3979954 packets
      Queueing
      (queue depth/total drops) 0/24
      (bytes output) 57810360602
      bandwidth remaining 4%
      dbl
          Probabilistic Drops: 35 Packets
          Belligerent Flow Drops: 2481 Packets
      119138976 packets
        119138976 packets
    Class-map: Shape-10M (match-any)
      55323893 packets
      Match: access-group 102
        55323893 packets
    Class-map: Shape-20M (match-any)
      0 packets
      Match: access-group 103
        0 packets
      14394370619 packets
      Match: any
      Queueing
      queue limit 3024 packets
      (queue depth/total drops) 0/2058
      (bytes output) 17449931138915
      bandwidth remaining 25%
      dbl
          Probabilistic Drops: 1815712 Packets
          Belligerent Flow Drops: 11121536 Packets
