Tried everything, but still high CPU utilisation on 2811 router
WalterKlomp
Hi Experts,
I have read an tried just about everything regarding CPU utilisation... I can't for the life of me figure out why the interrupt driven CPU usage is so high.
At around 6Mbps of VoIP traffic, the router is 100% CPU and it start dropping packets all over the place.
there is no logging in the access-list (there is only one inbound access list).
Using QoS or not, doesn't seem to make a difference
All route-caching features are ON. (CEF, Flow, Policy, Fast)
Yet the minimum CPU utilisation I have seen is 25%/25%... On average it's 40% during the day, but once traffic picks up to around 6000 packets per second, the router is gone...
I have a 50/50 Mbps connection, but I can use only 6 for VoIP ?
I hope somebody can help me.
Walter.
Show interfaces:
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0014.1c26.7c30 (bia 0014.1c26.7c30)
  Description: $ETH-LAN$$FW_INSIDE$
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 6/255, rxload 7/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 11:55:29
  Input queue: 2/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/100/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 4/4 (allocated/max allocated)
     Available Bandwidth 4000 kilobits/sec
  5 minute input rate 2793000 bits/sec, 3488 packets/sec
  5 minute output rate 2734000 bits/sec, 3632 packets/sec
     116982865 packets input, 3127961458 bytes, 0 no buffer
     Received 80940 broadcasts, 0 runts, 0 giants, 0 throttles
     776 input errors, 0 CRC, 0 frame, 0 overrun, 776 ignored
     0 watchdog, 0 multicast, 0 pause input
     122381088 packets output, 2917881813 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier, 955 pause output
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0014.1c26.7c31 (bia 0014.1c26.7c31)
  Description: $FW_OUTSIDE$
  MTU 1500 bytes, BW 50000 Kbit, DLY 100 usec,
     reliability 255/255, txload 12/255, rxload 12/255
  Last input 00:00:08, output 00:00:00, output hang never
  Last clearing of "show interface" counters 11:55:35
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Available Bandwidth 2000 kilobits/sec
  5 minute input rate 2382000 bits/sec, 3384 packets/sec
  5 minute output rate 2422000 bits/sec, 3233 packets/sec
     112019602 packets input, 1309720228 bytes, 0 no buffer
     Received 37 broadcasts, 0 runts, 0 giants, 0 throttles
     6 input errors, 0 CRC, 0 frame, 0 overrun, 6 ignored
     106502288 packets output, 1491121361 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 8 pause output
Show interface switching:
GigabitEthernet0/0 $ETH-LAN$$FW_INSIDE$
          Throttle count          6
                   Drops         RP          8         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    2571886      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process    2466474  232989228     834642  682286322
            Cache misses          0          -          -          -
                    Fast 1605087272   84348648 1819463644 4147073402
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0       2826     217602
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process    2568233  154045020     443185   26591100
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process     113630   41256882     170349   10220940
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
GigabitEthernet0/1 $FW_OUTSIDE$
          Throttle count          3
                   Drops         RP         15         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs       9773      Drops          0
    Protocol  IP
                 Process    1779287 1333404015     349499   37612434
            Cache misses        172          -          -          -
                    Fast 1319796001 2010536801 1103515986  380354212
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       1420      85200       1422      85320
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0     170351   10221060
                    Fast          0          0         10       1100
               Auton/SSE          0          0          0          0
Show proc cpu sort looks like this at the moment:
CPU utilization for five seconds: 42%/41%; one minute: 41%; five minutes: 39%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
200     1147508     28799      39845  0.31%  0.03%  0.00%   0 Per-minute Jobs
  36      793656   1702120        466  0.07%  0.01%  0.00%   0 Per-Second Jobs
   2        9600    340675         28  0.00%  0.00%  0.00%   0 Load Meter
   3         832     19243         43  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
   5           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   7      592608     35982      16469  0.00%  0.00%  0.00%   0 Pool Manager
   6     2564412    211190      12142  0.00%  0.04%  0.05%   0 Check heaps
   9           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
   8           0         2          0  0.00%  0.00%  0.00%   0 Timers
  11       10240     56780        180  0.00%  0.00%  0.00%   0 Environmental mo
  12         120     28391          4  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  13           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  10           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  15       22864   1702016         13  0.00%  0.00%  0.00%   0 IPC Deferred Por
  16           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  17           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  18      915940   2486783        368  0.00%  0.02%  0.00%   0 ARP Input
   1         164       113       1451  0.00%  0.00%  0.00%   0 Chunk Manager
  20           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  21           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  22           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  23           0         2          0  0.00%  0.00%  0.00%   0 Entity MIB API
  24        4944    340578         14  0.00%  0.00%  0.00%   0 HC Counter Timer
  25           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  14       23928   1702015         14  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  28       24552   1702012         14  0.00%  0.00%  0.00%   0 GraphIt
  29           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  30           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  31           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  32           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  33       27940    274500        101  0.00%  0.00%  0.00%   0 Net Background
  34        2680     54419         49  0.00%  0.00%  0.00%   0 Logger
  35       55040   1702009         32  0.00%  0.00%  0.00%   0 TTY Background
  26           4         1       4000  0.00%  0.00%  0.00%   0 MPLS HC Counter
  37        4444       498       8923  0.00%  0.00%  0.00% 322 Virtual Exec
  38           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  39           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  40           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  41           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  42           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  43           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  44           0         2          0  0.00%  0.00%  0.00%   0 ESWPPM
  45           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  46           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  47           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  48       38084   6754866          5  0.00%  0.00%  0.00%   0 Netclock Backgro
  49           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  27           0         2          0  0.00%  0.00%  0.00%   0 SMART
  51           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  52           0         1          0  0.00%  0.00%  0.00%   0 DSPFARM DSP READ
  50        1884    283828          6  0.00%  0.00%  0.00%   0 mxt5100
  54           0         1          0  0.00%  0.00%  0.00%   0 HDV background
  55           0         2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
  56           0         1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
  57           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  58           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  59         188     56780          3  0.00%  0.00%  0.00%   0 Call Management
  60           0         1          0  0.00%  0.00%  0.00%   0 AAL2CPS TIMER_CU
  61           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  62       10536   1702018          6  0.00%  0.00%  0.00%   0 Crypto Device Up
  64           0         2          0  0.00%  0.00%  0.00%   0 dot1x
  65           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  66       13908   1702012          8  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  67         516    170320          3  0.00%  0.00%  0.00%   0 EtherChnl
  68           0         1          0  0.00%  0.00%  0.00%   0 L2X Data Daemon
  69           0         2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  70           0         1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  71           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  72           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  73          20       161        124  0.00%  0.00%  0.00%   0 AAA Server
  74           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  75           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  76           0         1          0  0.00%  0.00%  0.00%   0 AC Mgr
  78        3920     27218        144  0.00%  0.00%  0.00%   0 EM FD Syslog
  79           0         2          0  0.00%  0.00%  0.00%   0 EM FD SNMP
  80           0         2          0  0.00%  0.00%  0.00%   0 EM FD Memory Thr
  81           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
  82           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
  83     1952492   2153707        906  0.00%  0.00%  0.00%   0 IP Input
  84           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  85           0        52          0  0.00%  0.00%  0.00%   0 TurboACL
  87           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  88           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  89        1164    227099          5  0.00%  0.00%  0.00%   0 SSS Test Client
  90           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  91       32544   6653217          4  0.00%  0.00%  0.00%   0 SSS Feature Time
  92           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  93           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  94           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  95           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  96           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  97           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  98           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
  99       14268     55166        258  0.00%  0.00%  0.00%   0 IP Background
100        3140     28401        110  0.00%  0.00%  0.00%   0 IP RIB Update
  53           0         2          0  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
102           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
103           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
104         952     14945         63  0.00%  0.00%  0.00%   0 TCP Timer
105          88        62       1419  0.00%  0.00%  0.00%   0 TCP Protocols
106           0         1          0  0.00%  0.00%  0.00%   0 COPS
107      385868   2177778        177  0.00%  0.00%  0.00%   0 CEF process
101           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
109           0         1          0  0.00%  0.00%  0.00%   0 MRD
110           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN
111           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
112           0         2          0  0.00%  0.00%  0.00%   0 DDP
113           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
114           4         2       2000  0.00%  0.00%  0.00%   0 SCTP Main Proces
115           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
116       44956   1702018         26  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
117           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
118       12636   1702017          7  0.00%  0.00%  0.00%   0 bsm_xmt_proc
119           0         1          0  0.00%  0.00%  0.00%   0 CES Client SVC R
120       24920   3328139          7  0.00%  0.00%  0.00%   0 IP NAT Ager
121           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
122        9864     28373        347  0.00%  0.00%  0.00%   0 IP Cache Ager
123        4308     28393        151  0.00%  0.00%  0.00%   0 Adj Manager
124       30476     56338        540  0.00%  0.00%  0.00%   0 HTTP CORE
125           0        33          0  0.00%  0.00%  0.00%   0 RARP Input
126           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
127           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
128           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
129           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
130       67080  17006612          3  0.00%  0.00%  0.00%   0 RBSCP Background
131           0         2          0  0.00%  0.00%  0.00%   0 Tag Input
132        2488    340578          7  0.00%  0.00%  0.00%   0 L2F management d
133           4         1       4000  0.00%  0.00%  0.00%   0 PPTP Mgmt
134           0         2          0  0.00%  0.00%  0.00%   0 PPTP Data
135           0         1          0  0.00%  0.00%  0.00%   0 Inspect Timer
136           0         1          0  0.00%  0.00%  0.00%   0 Onboard VPN Comm
137          36      5679          6  0.00%  0.00%  0.00%   0 Authentication P
138           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
139           0         1          0  0.00%  0.00%  0.00%   0 IPS Timer
140           0         2          0  0.00%  0.00%  0.00%   0 SDEE Management
141           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
142           0         2          0  0.00%  0.00%  0.00%   0 URL filter proc
143           0         3          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
144         632     68141          9  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
145          96         2      48000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
146        5600    630378          8  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
147        2368    630376          3  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
148           0         4          0  0.00%  0.00%  0.00%   0 HDA DSPRM MAIN
149           0         3          0  0.00%  0.00%  0.00%   0 Crypto WUI
150           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
151           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
152           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
153           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
154         684      2618        261  0.00%  0.00%  0.00%   0 LOCAL AAA
156           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
157           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
158           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
159      790096     69403      11384  0.00%  0.00%  0.00%   0 Crypto Support
160           4         1       4000  0.00%  0.00%  0.00%   0 CCVPM_HTSP
161           0         2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
162           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
163          20      1893         10  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
164           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
166           0         1          0  0.00%  0.00%  0.00%   0 http client proc
167           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
168           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
169           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
170         392      3989         98  0.00%  0.00%  0.00%   0 crypto engine pr
171          40         4      10000  0.00%  0.00%  0.00%   0 Crypto CA
172           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
173           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
174         300      1644        182  0.00%  0.00%  0.00%   0 Crypto ACL
175           0         1          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
176      666252    118143       5639  0.00%  0.00%  0.00%   0 Crypto IKMP
177        4388     96314         45  0.00%  0.00%  0.00%   0 IPSEC key engine
178           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
179           8         8       1000  0.00%  0.00%  0.00%   0 Crypto PAS Proc
180         536      5782         92  0.00%  0.00%  0.00%   0 Crypto Delete Ma
181           0         2          0  0.00%  0.00%  0.00%   0 Key Proc
182           0         1          0  0.00%  0.00%  0.00%   0 PM Callback
183      370072      1186     312033  0.00%  0.00%  0.00%   0 crypto sw pk pro
184           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
185           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
186          32        78        410  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
187           0         5          0  0.00%  0.00%  0.00%   0 EM Server
188         480    170320          2  0.00%  0.00%  0.00%   0 RMON Recycle Pro
189           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
190           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
191         128      2136         59  0.00%  0.00%  0.00%   0 IpSecMibTopN
192           4         2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
193       19784   1701591         11  0.00%  0.00%  0.00%   0 trunk conditioni
194           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
195           0         2          0  0.00%  0.00%  0.00%   0 EM Applet Direct
196           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
198        9696    113592         85  0.00%  0.00%  0.00%   0 Net Input
199       13112    340580         38  0.00%  0.00%  0.00%   0 Compute load avg
108           0         2          0  0.00%  0.00%  0.00%   0 L2MM
201           0         1          0  0.00%  0.00%  0.00%   0 TCP Driver
202           0         1          0  0.00%  0.00%  0.00%   0 TCP Listener
203        2064     59056         34  0.00%  0.00%  0.00%   0 CEF Scanner
204         152       949        160  0.00%  0.00%  0.00%   0 SSH Event handle
205           0         1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
206        4428     66710         66  0.00%  0.00%  0.00%   0 IP VFR proc
207           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
208       28196     83210        338  0.00%  0.00%  0.00%   0 IP SNMP
209        8356     42033        198  0.00%  0.00%  0.00%   0 PDU DISPATCHER
210       33096     42036        787  0.00%  0.00%  0.00%   0 SNMP ENGINE
211           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
212           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
213       26192    307846         85  0.00%  0.00%  0.00%   0 NAT MIB Helper
214       25572   1730027         14  0.00%  0.00%  0.00%   0 NTP
17 Replies 17
Leo Laohoo
And what IOS are you running?
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.3(11)T6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 02-Jun-05 20:32 by ccai
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
c2821 uptime is 2 weeks, 5 days, 17 hours, 30 minutes
System returned to ROM by reload at 17:39:31 SGT Thu Apr 21 2011
System restarted at 17:41:50 SGT Thu Apr 21 2011
System image file is "flash:c2800nm-advipservicesk9-mz.123-11.T6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX0928A2U9
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Gawk!  That's an old IOS.
Can you post the result of the command "sh proc cpu | ex 0.00" please?
c2821#sh proc cpu | ex 0.00
CPU utilization for five seconds: 50%/50%; one minute: 50%; five minutes: 46%
c2821#
Have you tried upgrading your IOS?
is it any IOS bugg, why its not showing the process which is utilizing it.
Indeed upgrading to 12.4.24 did not help at all...
Looks I have another skeleton router in my datacenter....
Grrr....
Until what is the 2921 rated ?
Because the CPU is doing Hardware handling.
(50%/50% ) cpu has 50 % load and this goes the interupts.
Walter,
Upgrading the IOS  would be the first step I would look at and then check the cpu etc.
Kishore
I try that first... Will keep you posted on the progress...
Leo Laohoo
Ok.  This could be the suspect.  The 2811 is rated for 61 mbps - half duplex, no encryption.  Click on the link below:
Portable Product Sheets – Routing Performance
Im sorry to say that upgrading the ios on the box probably won't help you much.
I have also tried a 2811 for voice and it pretty much maxed out the cpu at around 5mbit/s of voice.
Upgraded to the 2921 instead, now running about 11mbit/s voice traffic with a cpu load of around 25%, it's really quite silly how much cpu is consumed by routing/nat:ing voip traffic.
Indeed, upgrading to 12.4.24 did not help at all...  I get some more processor output, but performance does not seem to be improved...
Anything I can improve on the performance until I get my new router?  (I am looking at 2921 or 2951)
I already removed the nbar recovery and Qos (I figure I do not need that with plenty of bandwidth to go)
also removing ip verify unicast reverse-path  gives a about 8% less CPU load...
interface GigabitEthernet0/0
description $ETH-LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip route-cache same-interface
no ip mroute-cache
duplex full
speed 100
no cdp enable
no mop enabled
hold-queue 100 out
interface GigabitEthernet0/1
description $FW_OUTSIDE$
bandwidth 50000
ip access-group 106 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip route-cache policy
no ip mroute-cache
duplex full
speed 100
no cdp enable
no mop enabled
crypto map SDM_CMAP_1
Have ip flow on a single interface, not both.
Disable "virtual-reassembly".
