Trouble configuring 2901 Router...
Ryan MacNeille
Hey guys & gals. I'm a noob with Cisco stuff and I'm fumbling my way through setting up this new router. I'm just trying to get nodes on the gi0/0 interface to access the internet. What am I missing?
Running config attached.
rizwanr74
Level 7
Level 7
Your ACL 101 should look like this?
ip access-list extended 101
 permit ip 10.10.10.0 255.255.255.248  any
You don't need ACL in the inside interfaces, which are secure interfaces, so please remove them
interface GigabitEthernet0/0
 no ip access-group allowall in
 no ip access-group allowall out
Now, where is your routed interface 10.10.10. 1?
default-router 10.10.10.1
Thank you very much for the help. The 10.10.10.0 network was on the router by default - I'm not using it.
I just have 0/0 as 6.1 for my internal network and 0/1 as my static WAN. All I need to do is route 6.0 traffic through to the internet.
"The 10.10.10.0 network was on the router by default - I'm not using it."
If you are not using it, why do you have a dhcp pool coming off that network?
Make your ACL 101, look like this...
 permit ip 192.168.6.0 255.255.255.0  any
You don't need ACL in the inside interfaces, which are secure interfaces, so please remove them.
