Cisco Interface Cards for Cisco 1921 router
Henri07
Hello, we have a Cisco 1921 router with one gigabit Ethernet port connected to a switch and the other to the Internet provider router. We are planning to connect it to another 1921 router. We need recommendations on some EHWIC or HWIC ethernet cards that are compatible with this router.
Thanks for your help.
Henri.
inderdeeps
Level 4
Level 4
@Henri07 : Check table number 4 on below link you will get to know all cards supported
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/ic/hardware/installation/guide/oview_ic.html
Inderdeep
www.thenetworkdna.com ( Award Winning blogs by Cisco)
inderdeeps
Level 4
Level 4
Inderdeep
Thank you, it was helpful.
Regards.
balaji.bandi
you are planning to buy new router or connect other ISP ?  - this model is EoL, you wont get officially selling.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/data_sheet_c78-660124.html
BB
Already purchased, thanks anyway.
Regards.
