troubleshooting metro ethernet link
erodrig
hi, i have a problem with a interenet metro ethernet link of 100 Mb, the int g0/1 is conected to my carrier and receive 100 mb link
interface GigabitEthernet0/1
description Conected to internet
ip address x.x.x.x 255.255.255.252
no ip proxy-arp
load-interval 30
duplex full
speed 100
media-type rj45
no negotiation auto
no cdp enable
and the int g0/2 is conected to the lan
interface GigabitEthernet0/2
description Puerto Red Lan Corporativo
ip address x.x.x.x 255.255.255.240
no ip proxy-arp
load-interval 30
duplex full
speed 100
media-type rj45
no negotiation auto
the problem is that the int g0/2 must be configured with speed 1000 for reach the 100 mb of total link to internet, if the int g0/2 is configured to speed 100 reach only about 20 mb of link.
i think that even both interfaces have the speed 100 comand must be reach the total link of 100 mb
is this correct??
thanks for your help
paolo bevilacqua
I think you're being mislead by some other issue.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You might want to confirm whether your vendor allows for full line rate.  Often service provider Ethernet hand-offs have bandwidth policy limits less the the physical medium supports.
It's also possible you vendor doesn't have the capacity to support full line rate.  In this case, if you have a service level agreement you can take this up with them.
Lastly, depending on location and bandwidth of the sites you're attempting to work against, they might have insufficient bandwidth and/or their or your TCP settings might be such that you'll not see full line usage with few flows.
