Troubleshooting PBR
acneurope
Hello All,
We've implemented PBR between our main and branch offices. However, it seems to have issues - the packet losses (via ping is extremely high, the traffic gets interrupted, etc. Does anyone have any information on how to troubleshoot it?
Here're the pieces of the relative configuration:
interface Vlan11
description $FW_INSIDE$
ip address 10.130.11.252 255.255.255.0
ip access-group vlan11-in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip inspect firewall in
ip virtual-reassembly
ip policy route-map RM-PBR-MPLS-VPN
no mop enabled
standby delay minimum 60 reload 60
standby version 2
standby 10 ip 10.130.11.250
standby 10 preempt delay minimum 60 reload 60 sync 60
standby 10 authentication md5 key-string 7 00211D0516421B120A250D
standby 10 name SNATHSRP
standby 10 track GigabitEthernet0/0
ip access-list extended PBR-MPLS
remark PBR Towards MPLS
permit ip 10.130.0.0 0.0.255.255 10.100.0.0 0.0.255.255
permit ip 10.130.0.0 0.0.255.255 10.120.0.0 0.0.255.255
permit ip 10.130.0.0 0.0.255.255 10.140.0.0 0.0.255.255
ip access-list extended PBR-MPLS-QoS
remark PBR Towards MPLS - Specific Applications
permit tcp host 10.130.12.30 eq telnet 10.140.0.0 0.0.255.255
permit tcp host 10.130.12.114 eq www 10.140.0.0 0.0.255.255
permit tcp host 10.130.12.145 eq 46997 host 10.140.20.25
ip access-list extended PBR-Tunnel0
remark PBR Towards Tunnel0
route-map RM-PBR-MPLS-VPN permit 10
match ip address PBR-MPLS-QoS
set ip next-hop 10.130.11.253
route-map RM-PBR-MPLS-VPN permit 20
match ip address PBR-Tunnel0
set ip next-hop verify-availability 10.63.0.2 10 track 11
route-map RM-PBR-MPLS-VPN permit 30
dgahm
Level 8
Level 8
You can start with a debug ip policy. If that doesn't help, you might want to debug ip packet 105. The 105 would be an access list defining the traffic you want to debug.
Your symptoms don't really sound like a PBR issue. Do non policy routed pings to the same destinations work OK? Have you tried turning off the IP Inspect?
Please rate helpful posts.
Dave
PBR works as expected, but after a day or two the above described sympthoms occur. I haven't tried desabling ip inspect. Will do that and will let you know.
Update: Just turned off ip inspect however, i can still see the packet loss. Weired thing is - if i remove PBR everything works just fine. Theres no errors on interfaces, cpu usage is very low..
Thx, Serge.
Hi Serge,
I saw your post after lot of search about this problem of packtried et loss when using PBR.
We face the similar problem on our IP/MPLS Backbone, several solutions but no success.
So I'd like to know if you finally found the solution of this problem.
Kind regards.
