Troubleshooting Tunnel Issue
Iloveyou
I ever had to troubleshoot an issue in which the encapsulation protocol of the tunnel was configured incorrectly.
However, the tunnel was still "up/up".
Why is the tunnel still "up/up" even though the encapsulation protocol was wrong?
16 Replies 16
You dont understand.
 valid tunnel source and tunnel destination is configured. Only tunnel encapsulation mismatch. So why is telling me up/up??
Joseph W. Doherty
BTW, just tried some tunnel config "stuff" in Packet Tracer (which cannot be counted on to be accurate on "real" Cisco platforms, but some it's accurate, so . . .).
The moment I configured a tunnel interface, tunnel interface appeared with status of up/down.
To get the tunnel to change status to up/up, had to insure 4 things.
Source interface that's up/up, with an IP address.
Tunnel interface with source defined (the aforementioned source interface).
Tunnel interface with any destination IP defined BUT router KNOWs and has a next hop for destination.
E.g.
conf t
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
Router>en
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int g0/0/0
Router(config-if)#ip address 1.1.1.1 255.255.255.0
Router(config-if)#no shut
Router(config-if)#
%LINK-5-CHANGED: Interface GigabitEthernet0/0/0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
int g0/0/0
Router(config-if)#int t1
Router(config-if)#tunnel source g0/0/0
Router(config-if)#tunnel destination 1.1.1.2
Router(config-if)#
%LINK-5-CHANGED: Interface Tunnel1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
