Trunking 2 Ports
AndreasStrummer
Hello Community,
i have got a SGE2000 switch and all i want to do is increase speed by trunking 2 ports. I understand it is done with VLAN.
Is that right and is there a How-To to download?
Txs for replies.
Andi
cadet alain
a trunk link in Cisco is a tagged port = a port which transports multiple VLANs.
If you want to increase speed you must do an etherchannel which is a logical bundling of physical ports.
But if your trafic flow is mainly between 1 src and 1 dst then you will not do load-balancing because the traffic in the bundle will always use the same physical port due to the load-balancing algorithm.
Regards.
Alain.
David Santos
Configure an Etherchannel
