Trunking
Lavanholy
I have a Cisco 4503 with the Fiber SFP port and say at a 500 meter distance I have a Cisco 3560G switch,I have multimode fiber between these switches,
now Can configure the port as a trunk port.
My guses is for trunking ,it is a layer 802.1q,there is no need to worry about the physical layer.Please clarify my doubts.
Thanks and Regards,
S.Venkataraman.
Istvan_Rabai
Level 7
Level 7
Hi Venkat,
You probably have an 1000Base-SX SFP module. It is OK for 550m distance.
Yes, you can configure it as a trunk port, similarly to this:
interface gig0/1
switchport
switchport mode trunk
Cheers:
Istvan
Istvan,
Thanks for the info.
S.Venkataraman.
shivlu jain
Level 5
Level 5
On L3 you canot configure a switch port as trunk without enableing dot1q on it.
regards
shivlu
Shivlu,
Obiviously,Thanks for the info.
S.Venkataraman.
