try to ping 8.8.8.8 and make it reachable
ahmed31
Would you guys help me make 8.8.8.8 reachable?
I did what was requested on my lap, but it did not work.
Pass for BranchR console: ConPa55sW
Pass for BranchR enable: BranchR
Pass for BranchSW console: ConPa55sW
Pass for BranchSW enable: BranchSW
requested :
To allow BranchTF PCs and Laptops to connect to Internet configure NAT in BranchR as follows:
  • Create an access-list defining allowed computers which can access internet
BranchR(config)#ip access-list standard BRANCH_OFFICE_LAN_To_INTERNET
BranchR(config-std-nacl)#permit 192.168.100.0 0.0.0.255
BranchR(config-std-nacl)#exit
  • Define inside and outside interfaces
BranchR(config)#int g0/0/0
BranchR(config-if)#ip nat outside
BranchR(config)#int g0/0/1
BranchR(config-if)#ip nat inside
  • Enable NAT/PAT
BranchR(config)#ip nat inside source list BRANCH_OFFICE_LAN_To_INTERNET interface g0/0/0 overload
2 Accepted Solutions
M02@rt37
Hello @ahmed31
On BranchR router please add static towards the ISP.
ip route 0.0.0.0 0.0.0.0 203.165.200.1
Best regards
M02@rt37
@ahmed31
Also take care the name of source list is not good!
After that PC should ping 8.8.8.8 !
Best regards
M02@rt37
Hello @ahmed31
Best regards
M02@rt37
@ahmed31
Best regards
balaji.bandi
As per the configuration looks ok (since i do not use PT - so not able to open that file)
As long as the IP address matches (check is the correct source IP)  that should work as expected
BB
Hello
The rtr credentials do not work
Kind Regards
Paul
