Cisco Router 2811 Configuration
ciscomoon
I have netgear modem i want to connet Cisco Router 2811 for natting. So what are the commands to configure the router. I got all the details for ADSl connection which provided by the ISP. i need step by step commands so that i can configure the router for natting purpose.
I want to bring another 2 computers on the network through the cisco 2811 router.
6 Replies 6
albayrak8791
1. create your pool
ip nat pool netmask
2. create access-list taht will allow your private address to be nat'ed
access-list 1 permit 192.168.1.0 0.0.0.255
3. do static translation if any needed
ip nat inside source static
4.inform your interfaces
int e0
ip nat inside
int s0
ip nat outside
5-start your nat
ip nat inside source list 1 pool [overload]
overload is optional if you have only one public ip address
i hope that helped...
ip nat pool testing 192.168.0.1 netmask 255.255.255.0
access-list 1 permit 192.168.0.1 255.255.255.0
int e0
ip nat inside
ip nat inside source list 1 pool testing
I tried above commands still not working.
My modem is on bridge mode. Where should i do ISP authentication.
Here is the connectivity details.
1. Netgear Modem
2. Cisco 2811 Router connected to Netgear Modem via crossover cable.
3. From the router its connected to catalyst 3560.
Can you please suggest how do i bring router and PCs on net.
To make ur router do the isp authentication
Step1:
Interface serial #connection to modem
description ADSL Internet connection
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
Step2
interface Dialer1
ip address dhcp # if u have static ip from ISP configure it#
ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname #####
ppp chap password 7 #######
Step 3: Nat and default route
(config)#ip route 0.0.0.0 0.0.0.0 dialer 1
(config)#access-list 10 permit 192.168.0.0 0.0.0.255
(config)#ip nat inside source list 10 interface dialer1 overload
u already have the ip nat inside command on
ur int e0
Hope this helps
Raj
Thanks for replying
When i am applying the above given commands i am getting error.
=============================================router#config t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#pppoe enable
% Invalid input detected at '^' marker.
router(config)#pppoe-client dial-pool-number 1
router(config)#^Z
router#
*Oct 9 22:25:15.958: %SYS-5-CONFIG_I: Configured from console by rafay on conso
le
router#pppoe-client dial-pool-number 1
router#
what is the reason?
Abdul,
'pppoe enable' is an interface command, not a global config command.
For further info on PPPoE implementation please read
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t2/dtpppofe.htm
_____
Please rate helpful posts.
