TTL and MTU Faiulures on Cisco7609
mpalis
Hello all
Running show mls statistic on a Cisco 7609 I get the follwing output form one of the modules
Errors
MAC/IP length inconsistencies : 18
Short IP packets received : 0
IP header checksum errors : 35
TTLfailures : 27831123
MTUfailures : 7998775
Is it normal to have so many TTL and MTU failures? What is the true meaning of this failures and how can we troubleshoot in order to minimize them?
Your feedback will be appreciated.
Harold Ritter
This might be normal depending on how long the switch has been running.
The TTL failures counter is incremented every time a received packet TTL reaches 0.
The MTU failure counter is incremented every time a received packet size exceeds the outbound interface MTU but can't be fragmented due to the DF bit being set in the ip header.
There is not much you can do to prevent these counters from incrementing.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
