09-02-2008 06:28 PM - edited 03-03-2019 11:22 PM
Hi all,
Is it possible to use two of cellular interface as primary?
Primary and backup use is not possible as far as I searched in Cisco.com.
I don't have two HWIC so can't confirm.
Cisco 3G WWAN HWIC Q&A Technical
Features and Functions
Can I configure the 3G HWIC WWAN cellular interface as the primary interface and
configure another interface as a backup to the cellular interface?
No. The 3G HWIC interface is an asynchronous serial, DDR interface.
You cannot configure another interface as the backup interface to any DDR interface
because the DDR interfaces themselves are designed to function primarily as backup interfaces.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/prod_qas0900aecd806e0563.pdf
Any reply will be apreciated!
Thank you,
Taichi
09-02-2008 09:28 PM
Never tried on this specific design, but I'm sure that ip sla can help you very much.
Bye,
Max.
09-03-2008 04:19 AM
Hello Taichi!
I have never worked with 3G WWAN HWIC, but as you wrote: "The 3G HWIC interface is an asynchronous serial", for me means that if you have 2 x 3G HWIC, you will have 2 interface that you can bundle and use them as a primary line.
Sorry if this is not what you intended to do!
Cheers,
Calin
