Two interfaces to ISP, tunnel configuration problem.
oshechodanov
In secondary office we have 2 low speed connection to ISP (ADSL modem with Ethernet). Each interfaces have own ip address. I want simultaneously use this interfaces to increase total bandwith of internet connection.
I think i can do:
interface Loopback1
ip address 2.2.2.2 255.255.255.252 secondary
ip address 1.1.1.1 255.255.255.252
ip nat outside
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.1
description To ISP 1
encapsulation dot1Q 1 native
ip unnumbered Loopback1
interface FastEthernet0/0.2
description To ISP 2
encapsulation dot1Q 2
interface FastEthernet0/0.3
description To LAN
encapsulation dot1Q 3
ip nat inside
ip route 0.0.0.0 0.0.0.0 Loopback1
ip nat pool NPL prefix-length 32
address 1.1.1.1 1.1.1.1
address 2.2.2.1 2.2.2.2
I think that must work. Is it right?
And we have second problem.
In main office we have high speed connection to ISP (other ISP in other city).
And we have to create tunnel to second office. I don't understand how configure routers to provide tunnel that can use two interfaces in second office (similar multilink ppp)
Thanks.
spremkumar
Level 9
Level 9
Neither you wont be able to route any traffic through your Loopback interface nor your will have next hop loopback ip address as your default exit point..
You need to point your default gateway pointing towards your fast ethernet subinterfaces..
Also you need to mention those interfaces as your nat outside interfaces..
You can mention those subinterfaces as your exit point followed by the next hop ip address in the ip route command itself..
regds
