12-13-2012 04:43 PM - edited 03-04-2019 06:24 PM
Can someone Please check my configuration an let me know if it is correct,
I want it such that, My Primary ISP works most of the time and all statically mapped IP's are used to access the Internet and server resources.
and all others use the dynamic Nat of 216.140.140.2 to access internet/resources.
And for the Secondary ISP which should only work when the Primary goes down, should work such that only its 7 staticall Nated servers access the internet/resources using their respective public ip, and all others should use the dynamic Nat.
Would appreciate any relevan help.
configuration::
ip sla 1
Icmp-Echo 216.140.140.1 source-ip 216.140.140.2
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
ip sla monitor 2
Icmp-Echo 216.150.150.254 source-ip 216.150.150.4
timeout 1000
threshold 2
frequency 3
ip sla schedule 2 life forever start-time now
track 1 sla 1 reachability
track 2 sla 2 reachability
interface gi0/0
ip address 10.0.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip policy route-map PRIVATE-INGRESS
duplex auto
speed auto
no keepalive
interface gi0/1
ip address 216.150.150.4 255.255.255.0 secondary
ip address 216.140.140.2 255.255.255.224
ip nat outside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 216.140.140.1 track 1
ip route 0.0.0.0 0.0.0.0 216.150.150.254 10
ip nat pool PRIMARY-POOL 216.140.140.2 216.140.140.2 prefix-length 27
ip nat pool SECONDARY-POOL 216.150.150.4 216.150.150.4 prefix-length 24
ip nat inside source route-map PRIMARY-NAT pool PRIMARY-POOL overload
ip nat inside source route-map SECONDARY-NAT pool SECONDARY-POOL overload
ip nat inside source static 10.0.0.52 216.140.140.4 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.53 216.140.140.5 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.59 216.140.140.6 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.61 216.140.140.7 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.228 216.140.140.8 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.16 216.140.140.11 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.30 216.140.140.12 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.251 216.140.140.13 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.44 216.140.140.15 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.54 216.140.140.16 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.23 216.140.140.17 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.58 216.140.140.18 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.230 216.140.140.19 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.216 216.140.140.21 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.220 216.140.140.22 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.33 216.140.140.25 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.21 216.140.140.26 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.22 216.140.140.27 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.24 216.140.140.28 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.25 216.140.140.29 route-map STATIC-NAT-PRIMARY
ip nat inside source static 10.0.0.59 216.150.150.5 route-map STATIC-NAT-SECONDARY
ip nat inside source static 10.0.0.52 216.150.150.6 route-map STATIC-NAT-SECONDARY
ip nat inside source static 10.0.0.53 216.150.150.7 route-map STATIC-NAT-SECONDARY
ip nat inside source static 10.0.0.16 216.150.150.8 route-map STATIC-NAT-SECONDARY
ip nat inside source static 10.0.0.58 216.150.150.9 route-map STATIC-NAT-SECONDARY
ip nat inside source static 10.0.0.61 216.150.150.11 route-map STATIC-NAT-SECONDARY
ip access-list standard PRIMARY-NEXT-HOP
permit 216.140.140.1
ip access-list standard SECONDARY-NEXT-HOP
permit 216.150.150.254
ip access-list standard TO-BE-NATTED-PRIMARY
deny 10.0.0.24
deny 10.0.0.25
deny 10.0.0.30
deny 10.0.0.16
deny 10.0.0.22
deny 10.0.0.23
deny 10.0.0.21
deny 10.0.0.33
deny 10.0.0.44
deny 10.0.0.58
deny 10.0.0.59
deny 10.0.0.61
deny 10.0.0.54
deny 10.0.0.52
deny 10.0.0.53
deny 10.0.0.216
deny 10.0.0.220
deny 10.0.0.230
deny 10.0.0.228
deny 10.0.0.251
permit 10.0.0.0 0.255.255.255
ip access-list standard TO-BE-NATTED-SECONDARY
deny 10.0.0.59
deny 10.0.0.52
deny 10.0.0.53
deny 10.0.0.16
deny 10.0.0.58
deny 10.0.0.61
route-map STATIC-NAT-PRIMARY permit 10
match ip next-hop PRIMARY-NEXT-HOP
route-map STATIC-NAT-PRIMARY deny 20
route-map STATIC-NAT-SECONDARY permit 10
match ip next-hop SECONDARY-NEXT-HOP
route-map STATIC-NAT-SECONDARY deny 20
route-map SECONDARY-NAT permit 10
match ip address TO-BE-NATTED-SECONDARY
route-map SECONDARY-NAT deny 20
route-map PRIVATE-INGRESS-PRIMARY permit 10
match ip address TO-BE-NATTED-PRIMARY
set ip next-hop verify-availability 216.140.140.1 10 track 1
route-map PRIVATE-INGRESS-PRIMARY permit 11
route-map PRIVATE-INGRESS-SECONDARY permit 10
set ip next-hop verify-availability 216.150.150.254 20 track 2
route-map PRIVATE-INGRESS-SECONDARY permit 11
route-map PRIMARY-NAT permit 10
route-map PRIMARY-NAT deny 20
12-13-2012 04:47 PM
Duplicate post #2.
