txload 255/255 but no traffic
krutibasa majhi
Hi all,
I am experiencing a strange problem with a ASR1002 router that I just  installed.thsi is a point to point link .the link is working  but for  some reason the txload on interface g0/0/0 show 255/255 even though  there is no traffic going over to this router.
Thanks in advance for any suggestions !!!
Please see the below interface status for both router.
Router#sh int gi0/0/3
GigabitEthernet0/0/3 is up, line protocol is up
  Hardware is 4XGE-BUILT-IN, address is a493.4c98.db03 (bia a493.4c98.db03)
  Description: "100Mbps LINK"
  Internet address is 10.172.20.110/30
  MTU 9100 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Keepalive not supported
  Full Duplex, 100Mbps, link type is auto, media type is T
  output flow-control is on, input flow-control is on
  Last input 00:46:49, output 00:00:29, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 7000 bits/sec, 4 packets/sec
  5 minute output rate 5000 bits/sec, 2 packets/sec
     17890 packets input, 9074660 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 7503 multicast, 0 pause input
     10137 packets output, 2803120 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Router#
RP/0/RSP0/CPU0:ASR-9010#sh int Gi0/0/0/13
Tue Oct 30 11:32:10.104 ist
GigabitEthernet0/0/0/13 is up, line protocol is up
  Interface state transitions: 11
  Hardware is GigabitEthernet, address is 18ef.63e8.6ce7 (bia 18ef.63e8.6ce7)
  Description: "100Mbps , Gi0/0/0/13"
  Internet address is 10.172.20.109/30
  MTU 9114 bytes, BW 100000 Kbit (Max: 100000 Kbit)
     reliability 253/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 100Mb/s, THD, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input 00:00:00, output 00:00:00
  Last clearing of "show interface" counters 22w6d
  30 second input rate 3000 bits/sec, 0 packets/sec
  30 second output rate 8000 bits/sec, 3 packets/sec
     665819 packets input, 159562042 bytes, 5896 total input drops
     1 drops for unrecognized upper-level protocol
     Received 21 broadcast packets, 99558 multicast packets
              350 runts, 1154 giants, 0 throttles, 0 parity
     5895 input errors, 2545 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2154457 packets output, 748147945 bytes, 0 total output drops
     Output 14647 broadcast packets, 1490193 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     11 carrier transitions
3 Accepted Solutions
Rahul Kukreja
This is due to the known defect -
CSCtw90305
Show interface X/Y returns output with counter txload 255/255
which was duplicated to CSCtr15153
Please use the Bug Tool Kit and verify your the IOS is affected or not.
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
- HTH
  Rahul
Leo Laohoo
I agree with Rahul.  This is a bug.  This bug was fixed on IOS version 15.2(2)S (aka 3.6.0).
ASIC Post initialization failed
Hardware failure.  There's nothing you can do about it except contact Cisco TAC and have the ME3800X RMA-ed.
7 Replies 7
Rahul Kukreja
CSCtw90305
- HTH
  Rahul
Thanks BOSS it working
Leo Laohoo
BOSS you are right .after upgrade it working.
thanks
I found a new problem in a new L3  Switch ME 3800X. It repeatedly restarts while I am swiching it on.  Through the consol its showing errors after flash initialization. If Im  breaking the operation it redirects it to switch prompt (switch:).
Errors:
1.Asic1, PB0 Training Failed.
2.ASIC Post initialization failed
3.driver class subsystem initialization failed
If anyone has a solution please help me.
Finally today  i logged in Cisco TAC
