ubr 7100 -- failover or load balancing using 2 DSL circuits
philstraton
I support a ubr 7100 with 50 endusers. I would like to set up either failover or load balancing using the 2 DSL lines that are attached.
When one of the DSL circuits went down today, none of the endusers could connect to the Internet.
I had to reconfigure as follows:
no ip name-server nn.nn.130.23
ip name-server nn.nn.28.12
no ip name-server nn.nn.131.5
ip name-server nn.nn.31.12
no route-map Mega permit 10
match ip address 8
set ip next-hop nn.nn.48.1
match ip address 8
set ip next-hop nn.nn.12.101
interface FastEthernet0/1
no ip address nn.nn.48.1 255.255.255.0
ip address nn.nn.12.102 255.255.255.252
Any suggestions? I know about routing BGP, but how do I set this up using statics?
Not applicable
If you have 2 different circuits each one with a separate block of addresses, and IF your ISP is not
performing some sort of source ip so it matches the block you have (something like the "verify
source unicast" command in IOS) then you could load balance your OUTGOING traffic to the
internet, but return traffic will always come back through the link that owns the ip address your
hosts used to go out. This is a limitation you would have on routing unless you own your block of
addresses and can run BGP with your ISP(s) in both links. Another solution would be for the router to load balance traffic out using both block of addresses that way the return traffic would come back on the corresponding link, but this would not allow you to statically assign an ip address to the hosts in your network. This would need to be worked out with NAT on the router and it would be load balanced per session.
