Unable to boot Cisco 1721 Router
suresh_shrestha
Hi All,
I have one Cisco 1721 which was working fine w/o any problem. But some days back due to unable to recall password being set into it, I just booted the Router with pressing Ctrl + Break key to go to rommon prompt, but it gets hanged.
Then I started the Router again, it never come up and even tried again with Ctrl + Break key, nothing comes into the console screen.
Appreciate if someone help me to make this Router bootable?
Suresh Shrestha
balajitvk
Level 4
Level 4
Hi Suresh,
Whether you are not able to see anything on the console or u r getting any o/p.
What is the LED status of the ports?? Showing up or down!
Rgs
Hi Balaji,
I can not see anything on the console at all.
LED I can see PWR & OK (Green). No other LEDs lighted.
Suresh
smothuku
Level 7
Level 7
Hi Suresh ,
Connect console cable to router and Try out with verious baud rates starting from min.value ...
At one point u should be able to access the router.
configuration register value may not be 0x2102 when you attempted to enter into rommon mode.
satish
