Bookmark
Subscribe
15615
unable to clear line vty on Cisco 7609
krutibasa majhi
Dear All,
I cannot eliminate the lines vty in my Cisco 7609 router
when I write show users, I obtain the following thing:
ROUTER-7609#show users
    Line       User       Host(s)              Idle       Location
   1 vty 0     suppot-oi idle                     4w4d 10.172.2.25
   2 vty 1     suport-oi idle                    2d23h 10.172.2.23
   3 vty 2     support-oi idle                 02:01:24 10.172.2.23
   4 vty 3     support-oi idle                    2d19h 10.172.2.23
*  5 vty 4     support-oi idle                 00:00:01 10.172.2.15
I try to erase it of the following way but I cannot:
ROUTER-7609#clear line vty 0
[confirm]y [OK]
the stranger, is that he says to me that has been ok, but when I make
"show users" again , it appears again.
Why it happen ?
my router Ver:
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRB3, RELEASE SOFTWARE (fc1)
please suggest !!!
Raju Sekharan
Seems the session is hung
Clear tcp tcb sometimes helps
Otherwie you need to do SUP-switchover if you have redundant SUPs or reload of the router
Could you paste the following output
Show tcp vty 0
Thank you
Raju
Rick Morris
Level 6
Level 6
you can also try:
Router# clear line 1
This will clear line 1 in your output which is VTY 0
