Unable to connect Dial up connections
We are having dialup 15  connections in router 3845 model  IOS version 12.4 1A.
We are unable to have a connection between dialup branches to headquarter. these are the command
aaa new-model
aaa authentication login telnet local
aaa authentication login ppp local
aaa authentication ppp ppp local
aaa authorization network ppp local
aaa session-id common
interface Group-Async1
description "ASYN-GROUP"
ip unnumbered GigabitEthernet0/1
encapsulation ppp
ip tcp header-compression
async dynamic routing
async mode interactive
peer default ip address pool pool
ppp authentication pap chap ppp
ppp authorization ppp
group-range 1/0 1/15
line aux 0
stopbits 1
line 1/0 1/15
login authentication local
modem Dialin
modem autoconfigure discovery
autoselect during-login
autoselect ppp
flowcontrol hardware
ip local pool pool 192.168.100.1 192.168.100.30
ip classless
When I tried to debug I found the below output :
RDCCI_2ND_HQ#
000381: *Sep 17 10:45:43.823: Modem 1/12 ACF: State: Ringing
000382: *Sep 17 10:45:43.823: Modem 1/12 ACF: Event: Incoming Ring
RDCCI_2ND_HQ#
000383: *Sep 17 10:45:45.295: Modem 1/12 ACF: Event: Hook state: Off Hook Answering
000384: *Sep 17 10:45:45.295: Modem 1/12 ACF: State: Answering
RDCCI_2ND_HQ#
000385: *Sep 17 10:46:06.723: Modem 1/12 ACF: Event: CONNECT V34/LAPM/V44/24000:TX/26400:RX
000386: *Sep 17 10:46:06.723: Modem 1/12 ACF: State: Connected
000387: *Sep 17 10:46:07.695: TTY1/12: DSR came up
000388: *Sep 17 10:46:07.695: tty1/12: Modem: IDLE->(unknown)
000389: *Sep 17 10:46:07.695: TTY1/12: EXEC creation
000390: *Sep 17 10:46:07.695: AAA/BIND(00000017): Bind i/f Async1/12
000391: *Sep 17 10:46:07.695: TTY1/12: create timer type 10, 30 seconds
RDCCI_2ND_HQ#
000392: *Sep 17 10:46:11.071: TTY1/12: Autoselect(2) sample [suppressed--line is not echoing]
000393: *Sep 17 10:46:11.071: TTY1/12: Autoselect(2) sample [suppressed--line is not echoing]
000394: *Sep 17 10:46:11.075: TTY1/12: Autoselect(2) sample [suppressed--line is not echoing]
000395: *Sep 17 10:46:11.075: TTY1/12: Autoselect(2) sample 7EFF7D23
000396: *Sep 17 10:46:11.075: TTY1/12 Autoselect cmd:  ppp negotiate
000397: *Sep 17 10:46:11.075: TTY1/12: pause timer type 10 (OK)
000398: *Sep 17 10:46:11.075: TTY1/12: EXEC creation
000399: *Sep 17 10:46:11.075: TTY1/12: create timer type 1, 600 seconds
000400: *Sep 17 10:46:11.075: As1/12 PPP: Consuming data in TTY1/12 receive queue
000401: *Sep 17 10:46:11.075: APPP1/12: Input packet, len = 27, header = FF 3 C0 21
000402: *Sep 17 10:46:11.075: As1/12 PPP: Caching packet rcvd on TTY1/12
000403: *Sep 17 10:46:11.075: Async1/12: Setup PPP framing on TTY1/12
000404: *Sep 17 10:46:11.075: TTY1/12: destroy timer type 1
000405
RDCCI_2ND_HQ#: *Sep 17 10:46:11.075: TTY1/12: no timer type 0 to destroy
000406: *Sep 17 10:46:11.075: TTY1/12: no timer type 2 to destroy
000407: *Sep 17 10:46:11.075: As1/12 PPP: Async Protocol Mode started for 0.0.0.0
000408: *Sep 17 10:46:11.075: As1/12 PPP: I pkt type 0xC021, datagramsize 27 link[ppp]
000409: *Sep 17 10:46:11.075: As1/12 PPP: I pkt type 0xC021, datagramsize 27 link[ppp]
000410: *Sep 17 10:46:11.075: As1/12 PPP: Processed packet cached during autoselect
000411: *Sep 17 10:46:11.075: As1/12 LCP: I CONFREQ [Closed] id 0 len 23
000412: *Sep 17 10:46:11.075: As1/12 LCP:    ACCM 0x00000000 (0x020600000000)
000413: *Sep 17 10:46:11.075: As1/12 LCP:    MagicNumber 0x56920282 (0x050656920282)
000414: *Sep 17 10:46:11.075: As1/12 LCP:    PFC (0x0702)
000415: *Sep 17 10:46:11.075: As1/12 LCP:    ACFC (0x0802)
000416: *Sep 17 10:46:11.075: As1/12 LCP:    Callback 6  (0x0D0306)
000417: *Sep 17 10:46:11.075: As1/12: Enabling PPP framing in UART Microcode on TTY1/12 succeeded
000418: *Sep 17 10:46:11.075: As1/12 LCP: Lower layer not up, Fast Starting
000419: *Sep 17 10:46:11.075: As1/12 PPP: Using modem call direction
000420: *Sep 17 10:46:11.075: As1/12 PPP: Treating connection as a callin
000421: *Sep 17 10:46:11.075: As1/12 PPP: Session handle[800001A] Session id[19]
000422: *Sep 17 10:46:11.075: As1/12 PPP: Phase is ESTABLISHING, Passive Open
000423: *Sep 17 10:46:11.075: As1/12 LCP: State is Listen
000424: *Sep 17 10:46:11.075: As1/12 LCP: O CONFREQ [Listen] id 13 len 24
000425: *Sep 17 10:46:11.075: As1/12 LCP:    ACCM 0x000A0000 (0x0206000A0000)
000426: *Sep 17 10:46:11.075: As1/12 LCP:    AuthProto PAP (0x0304C023)
000427: *Sep 17 10:46:11.075: As1/12 LCP:    MagicNumber 0x14A18BAE (0x050614A18BAE)
000428: *Sep 17 10:46:11.079: As1/12 LCP:    PFC (0x0702)
000429: *Sep 17 10:46:11.079: As1/12 LCP:    ACFC (0x0802)
000430: *Sep 17 10:46:11.079: As1/12 LCP: O CONFREJ [Listen] id 0 len 7
000431: *Sep 17 10:46:11.079: As1/12 LCP:    Callback 6  (0x0D0306)
000432: *Sep 17 10:46:11.079: Modem 1/12 ACF: CMD PPP mode active
000433: *Sep 17 10:46:11.079: Modem 1/12 ACF: CMD PPP escape maps set: TX map=00000000 RX map=FFFFFFFF
000434: *Sep 17 10:46:11.079: %LINK-3-UPDOWN: Interface Async1/12, changed state to up
000435: *Sep 17 10:46:11.559: As1/12 PPP: I pkt type 0xC021, datagramsize 28 link[ppp]
000436: *Sep 17 10:46:11.559: As1/12 PPP: I pkt type 0xC021, datagramsize 28 link[ppp]
000437: *Sep 17 10:46:11.559: As1/12 LCP: I CONFACK [REQsent] id 13 len 24
000438: *Sep 17 10:46:11.559: As1/12 LCP:    ACCM 0x000A0000 (0x0206000A0000)
000439: *Sep 17 10:46:11.559: As1/12 LCP:    AuthProto PAP (0x0304C023)
000440: *Sep 17 10:46:11.559: As1/12 LCP:    MagicNumber 0x14A18BAE (0x050614A18BAE)
000441: *Sep 17 10:46:11.559: As1/12 LCP:    PFC (0x0702)
000442: *Sep 17 10:46:11.559: As1/12 LCP:    ACFC (0x0802)
000443: *Sep 17 10:46:11.563: As1/12 PPP: I pkt type 0xC021, datagramsize 24 link[ppp]
000444: *Sep 17 10:46:11.563: As1/12 PPP: I pkt type 0xC021, datagramsize 24 link[ppp]
000445: *Sep 17 10:46:11.563: As1/12 LCP: I CONFREQ [ACKrcvd] id 1 len 20
000446: *Sep 17 10:46:11.563: As1/12 LCP:    ACCM 0x00000000 (0x020600000000)
000447: *Sep 17 10:46:11.563: As1/12 LCP:    MagicNumber 0x56920282 (0x050656920282)
000448: *Sep 17 10:46:11.563: As1/12 LCP:    PFC (0x0702)
000449: *Sep 17 10:46:11.563: As1/12 LCP:    ACFC (0x0802)
000450: *Sep 17 10:46:11.563: As1/12 LCP: O CONFACK [ACKrcvd] id 1 len 20
000451: *Sep 17 10:46:11.563: As1/12 LCP:    ACCM 0x00000000 (0x020600000000)
000452: *Sep 17 10:46:11.563: As1/12 LCP:    MagicNumber 0x56920282 (0x050656920282)
000453: *Sep 17 10:46:11.563: As1/12 LCP:    PFC (0x0702)
000454: *Sep 17 10:46:11.563: As1/12 LCP:    ACFC (0x0802)
000455: *Sep 17 10:46:11.567: As1/12 LCP: State is Open
000456: *Sep 17 10:46:11.567: As1/12 PPP: Phase is AUTHENTICATING, by this end
000457: *Sep 17 10:46:11.567: Modem 1/12 ACF: CMD PPP escape maps set: TX map=00000000 RX map=00000000
000458: *Sep 17 10:46:11.859: As1/12 PPP: I pkt type 0xC021, datagramsize 20 link[ppp]
000459: *Sep 17 10:46:11.859: As1/12 PPP: I pkt type 0xC021, datagramsize 20 link[ppp]
000460: *Sep 17 10:46:11.859: As1/12 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x56920282 MSRASV5.20
000461: *Sep 17 10:46:11.863: As1/12 PPP: I pkt type 0xC021, datagramsize 25 link[ppp]
000462: *Sep 17 10:46:11.863: As1/12 PPP: I pkt type 0xC021, datagramsize 25 link[ppp]
000463: *Sep 17 10:46:11.863: As1/12 LCP: I IDENTIFY [Open] id 3 len 23 magic 0x56920282 MSRAS-0-ITADMIN
000464: *Sep 17 10:46:11.863: As1/12 PPP: I pkt type 0xC021, datagramsize 26 link[ppp]
000465: *Sep 17 10:46:11.863: As1/12 PPP: I pkt type 0xC021, datagramsize 26 link[ppp]
000466: *Sep 17 10:46:11.863: As1/12 LCP: I IDENTIFY [Open] id 4 len 24 magic 0x56920282 \}3nk[^F?SVT]=}E
000467: *Sep 17 10:46:11.867: As1/12 PPP: I pkt type 0xC023, datagramsize 16 link[ppp]
000468: *Sep 17 10:46:11.867: As1/12 PPP: I pkt type 0xC023, datagramsize 16 link[ppp]
000469: *Sep 17 10:46:11.867: As1/12 PAP: I AUTH-REQ id 2 len 14 from "test"
000470: *Sep 17 10:46:11.867: As1/12 PAP: Authenticating peer test
000471: *Sep 17 10:46:11.867: As1/12 PPP: Phase is FORWARDING, Attempting Forward
000472: *Sep 17 10:46:11.867: As1/12 PPP: Phase is AUTHENTICATING, Unauthenticated User
000473: *Sep 17 10:46:11.867: As1/12 PPP: Phase is FORWARDING, Attempting Forward
000474: *Sep 17 10:46:11.867: As1/12 PPP: Phase is AUTHENTICATING, Authenticated User
000475: *Sep 17 10:46:11.867: AAA/AUTHOR (0x17): Pick method list 'ppp'
000476: *Sep 17 10:46:11.867: AAA/AUTHOR (0x17): Pick method list 'ppp'
000477: *Sep 17 10:46:11.867: As1/12 PPP/AAA: Check Attr: Framed-Protocol
000478: *Sep 17 10:46:11.867: As1/12 PPP/AAA: Check Attr: username
000479: *Sep 17 10:46:11.867: As1/12 AAA/AUTHOR/FSM: We can start LCP
000480: *Sep 17 10:46:11.867: As1/12 PPP/AAA: Check Attr: Framed-Protocol
000481: *Sep 17 10:46:11.867: As1/12 PPP/AAA: Check Attr: username
000482: *Sep 17 10:46:11.867: As1/12 AAA/AUTHOR/FSM: We can start IPCP
000483: *Sep 17 10:46:11.867: As1/12 AAA/AUTHOR/LCP: Process Author
000484: *Sep 17 10:46:11.867: As1/12 PAP: O AUTH-ACK id 2 len 5
000485: *Sep 17 10:46:11.867: As1/12 PPP: Phase is UP
000486: *Sep 17 10:46:11.867: As1/12 AAA/AUTHOR/IPCP: Already authorized
000487: *Sep 17 10:46:11.867: As1/12 AAA/AUTHOR/FSM: We can start IPCP
000488: *Sep 17 10:46:11.867: As1/12 IPCP: O CONFREQ [Closed] id 1 len 16
000489: *Sep 17 10:46:11.867: As1/12 IPCP:    CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
000490: *Sep 17 10:46:11.867: As1/12 IPCP:    Address 192.168.100.1 (0x0306C0A86401)
000491: *Sep 17 10:46:11.867: As1/12 PPP: Process pending ncp packets
000492: *Sep 17 10:46:12.163: As1/12 PPP: I pkt type 0x8057, datagramsize 16 link[ipv6]
000493: *Sep 17 10:46:12.163: As1/12 PPP: I pkt type 0x8057, datagramsize 16 link[ipv6]
000494: *Sep 17 10:46:12.163: As1/12 IPV6CP: I CONFREQ [Not negotiated] id 5 len 14
000495: *Sep 17 10:46:12.163: As1/12 IPV6CP:    Interface-Id 6C47:6D95:1AE3:2F30 (0x010A6C476D951AE32F30)
000496: *Sep 17 10:46:12.163: As1/12 LCP: O PROTREJ [Open] id 14 len 20 protocol IPV6CP (0x80570105000E010A6C476D951AE32F30)
000497: *Sep 17 10:46:12.163: As1/12 PPP: I pkt type 0x80FD, datagramsize 12 link[ccp]
000498: *Sep 17 10:46:12.163: As1/12 PPP: I pkt type 0x80FD, datagramsize 12 link[ccp]
000499: *Sep 17 10:46:12.163: As1/12 CCP: I CONFREQ [Not negotiated] id 6 len 10
000500: *Sep 17 10:46:12.163: As1/12 CCP:    MS-PPC supported bits 0x00000001 (0x120600000001)
000501: *Sep 17 10:46:12.163: As1/12 LCP: O PROTREJ [Open] id 15 len 16 protocol CCP (0x80FD0106000A120600000001)
000502: *Sep 17 10:46:12.171: As1/12 PPP: I pkt type 0x8021, datagramsize 42 link[ip]
000503: *Sep 17 10:46:12.171: As1/12 PPP: I pkt type 0x8021, datagramsize 42 link[ip]
000504: *Sep 17 10:46:12.171: As1/12 IPCP: I CONFREQ [REQsent] id 7 len 40
000505: *Sep 17 10:46:12.171: As1/12 IPCP:    CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
000506: *Sep 17 10:46:12.171: As1/12 IPCP:    Address 0.0.0.0 (0x030600000000)
000507: *Sep 17 10:46:12.171: As1/12 IPCP:    PrimaryDNS 0.0.0.0 (0x810600000000)
000508: *Sep 17 10:46:12.171: As1/12 IPCP:    PrimaryWINS 0.0.0.0 (0x820600000000)
000509: *Sep 17 10:46:12.171: As1/12 IPCP:    SecondaryDNS 0.0.0.0 (0x830600000000)
000510: *Sep 17 10:46:12.171: As1/12 IPCP:    SecondaryWINS 0.0.0.0 (0x840600000000)
000511: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: Start.  Her address 0.0.0.0, we want 0.0.0.0
000512: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: Authorization succeeded
000513: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: Done.  Her address 0.0.0.0, we want 0.0.0.0
000514: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/CONFIG: Pools refreshed for pool pool
000515: *Sep 17 10:46:12.171: AAA/AUTHOR (0x17): Invalid method list id=0x0
000516: *Sep 17 10:46:12.171: As1/12 IPCP: Cannot satisfy pool request
000517: *Sep 17 10:46:12.171: As1/12 IPCP: Neither side knows remote address
000518: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: no author-info for primary dns
000519: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: no author-info for primary wins
000520: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: no author-info for seconday dns
000521: *Sep 17 10:46:12.171: As1/12 AAA/AUTHOR/IPCP: no author-info for seconday wins
000522: *Sep 17 10:46:12.171: As1/12 IPCP: O CONFREJ [REQsent] id 7 len 22
000523: *Sep 17 10:46:12.171: As1/12 IPCP:    Address 0.0.0.0 (0x030600000000)
000524: *Sep 17 10:46:12.171: As1/12 IPCP:    PrimaryWINS 0.0.0.0 (0x820600000000)
000525: *Sep 17 10:46:12.171: As1/12 IPCP:    SecondaryWINS 0.0.0.0 (0x840600000000)
000526: *Sep 17 10:46:12.171: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000527: *Sep 17 10:46:12.171: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000528: *Sep 17 10:46:12.171: As1/12 IPCP: I CONFACK [REQsent] id 1 len 16
000529: *Sep 17 10:46:12.171: As1/12 IPCP:    CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
000530: *Sep 17 10:46:12.171: As1/12 IPCP:    Address 192.168.100.1 (0x0306C0A86401)
000531: *Sep 17 10:46:12.447: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000532: *Sep 17 10:46:12.447: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000533: *Sep 17 10:46:12.447: As1/12 IPCP: I CONFREQ [ACKrcvd] id 8 len 16
000534: *Sep 17 10:46:12.447: As1/12 IPCP:    CompressType VJ 15 slots CompressSlotID (0x0206002
%This command has no effect on this line; use modem AT commands insteadD0F01)
000535: *Sep 17 10:46:12.447: As1/12 IPCP:    Address 0.0.0.0 (0x030600000000)
000536: *Sep 17 10:46:12.447: As1/12 AAA/AUTHOR/IPCP: Start.  Her address 0.0.0.0, we want 0.0.0.0
000537: *Sep 17 10:46:12.447: As1/12 AAA/AUTHOR/IPCP: Authorization succeeded
000538: *Sep 17 10:46:12.447: As1/12 AAA/AUTHOR/IPCP: Done.  Her address 0.0.0.0, we want 0.0.0.0
000539: *Sep 17 10:46:12.447: As1/12 AAA/AUTHOR/CONFIG: Pool pool refresh skipped
000540: *Sep 17 10:46:12.447: As1/12 AAA/AUTHOR/CONFIG: Pools refreshed 0 seconds ago
000541: *Sep 17 10:46:12.447: As1/12 IPCP: Cannot satisfy pool request
000542: *Sep 17 10:46:12.447: As1/12 IPCP: Neither side knows remote address
000543: *Sep 17 10:46:12.447: As1/12 IPCP: O CONFREJ [ACKrcvd] id 8 len 10
000544: *Sep 17 10:46:12.447: As1/12 IPCP:    Address 0.0.0.0 (0x030600000000)
000545: *Sep 17 10:46:12.719: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000546: *Sep 17 10:46:12.719: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000547: *Sep 17 10:46:12.719: As1/12 IPCP: I TERMREQ [ACKrcvd] id 9 len 16 (0x56920282003CCD74000002E2)
000548: *Sep 17 10:46:12.719: As1/12 IPCP: O TERMACK [ACKrcvd] id 9 len 4
000549: *Sep 17 10:46:12.867: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async1/12, changed state to up
000550: *Sep 17 10:46:13.871: As1/12 IPCP: TIMEout: State REQsent
000551: *Sep 17 10:46:13.871: As1/12 IPCP: O CONFREQ [REQsent] id 2 len 16
000552: *Sep 17 10:46:13.871: As1/12 IPCP:    CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
000553: *Sep 17 10:46:13.871: As1/12 IPCP:    Address 192.168.100.1 (0x0306C0A86401)
000554: *Sep 17 10:46:14.327: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000555: *Sep 17 10:46:14.327: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000556: *Sep 17 10:46:14.327: As1/12 IPCP: I TERMACK [REQsent] id 2 len 16 (0x0206002D0F010306C0A86401)
000557: *Sep 17 10:46:15.887: As1/12 IPCP: TIMEout: State REQsent
000558: *Sep 17 10:46:15.887: As1/12 IPCP: O CONFREQ [REQsent] id 3 len 16
000559: *Sep 17 10:46:15.887: As1/12 IPCP:    CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
000560: *Sep 17 10:46:15.887: As1/12 IPCP:    Address 192.168.100.1 (0x0306C0A86401)
000561: *Sep 17 10:46:16.139: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000562: *Sep 17 10:46:16.139: As1/12 PPP: I pkt type 0x8021, datagramsize 18 link[ip]
000563: *Sep 17 10:46:16.139: As1/12 IPCP: I TERMACK [REQsent] id 3 len 16 (0x0206002D0F010306C0A86401)
000564: *Sep 17 10:46:17.747: As1/12 PPP: I pkt type 0xC021, datagramsize 20 link[ppp]
000565: *Sep 17 10:46:17.747: As1/12 PPP: I pkt type 0xC021, datagramsize 20 link[ppp]
000566: *Sep 17 10:46:17.747: As1/12 LCP: I TERMREQ [Open] id 10 len 16 (0x56920282003CCD7400000000)
000567: *Sep 17 10:46:17.747: As1/12 LCP: O TERMACK [Open] id 10 len 4
000568: *Sep 17 10:46:17.751: As1/12 PPP: Sending Acct Event[Down] id[17]
000569: *Sep 17 10:46:17.751: As1/12 IPCP: State is Closed
000570: *Sep 17 10:46:17.751: As1/12 PPP: Phase is TERMINATING
000571: *Sep 17 10:46:18.667: Modem 1/12 ACF: Event: Hook state: On Hook
000572: *Sep 17 10:46:18.667: Modem 1/12 ACF: State: Hangup
000573: *Sep 17 10:46:18.667: Modem 1/12 ACF: Event: DISCONNECT
000574: *Sep 17 10:46:18.667: Modem 1/12 ACF: State: Idle
000575: *Sep 17 10:46:18.695: TTY1/12: DSR was dropped
000576: *Sep 17 10:46:18.695: tty1/12: Modem: READY->HANGUP
000577: *Sep 17 10:46:18.695: TTY1/12: dropping DTR, hanging up
000578: *Sep 17 10:46:18.695: TTY1/12: Async Int reset: Dropping DTR
000579: *Sep 17 10:46:18.695: tty1/12: Modem: HANGUP->IDLE
000580: *Sep 17 10:46:18.695: Modem 1/12 ACF: CMD DTR set low
000581: *Sep 17 10:46:18.695: Modem 1/12 ACF: CMD DTR set low
000582: *Sep 17 10:46:18.751: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async1/12, changed state to down
000583: *Sep 17 10:46:19.695: TTY1/12: cleanup pending. Delaying DTR
000584: *Sep 17 10:46:19.695: TTY1/12: cleanup pending. Delaying DTR
000585: *Sep 17 10:46:19.759: As1/12 LCP: TIMEout: State TERMsent
000586: *Sep 17 10:46:19.759: As1/12 LCP: State is Closed
000587: *Sep 17 10:46:19.759: As1/12 PPP: Phase is DOWN
000588: *Sep 17 10:46:20.695: %LINK-5-CHANGED: Interface Async1/12, changed state to reset
000589: *Sep 17 10:46:20.695: TTY1/12: cleanup pending. Delaying DTR
000590: *Sep 17 10:46:20.695: TTY1/12: cleanup pending. Delaying DTR
000591: *Sep 17 10:46:21.695: TTY1/12: cleanup pending. Delaying DTR
000592: *Sep 17 10:46:21.695: TTY1/12: cleanup pending. Delaying DTR
000593: *Sep 17 10:46:22.695: TTY1/12: cleanup pending. Delaying DTR
000594: *Sep 17 10:46:22.695: TTY1/12: cleanup pending. Delaying DTR
000595: *Sep 17 10:46:23.695: Async1/12: Async protocol mode stopped for 0.0.0.0
000596: *Sep 17 10:46:23.695: Async1/12: Reset PPP framing on TTY1/12
000597: *Sep 17 10:46:23.695: TTY1/12: no timer type 0 to destroy
000598: *Sep 17 10:46:23.695: TTY1/12: no timer type 1 to destroy
000599: *Sep 17 10:46:23.695: TTY1/12: no timer type 3 to destroy
000600: *Sep 17 10:46:23.695: TTY1/12: no timer type 4 to destroy
000601: *Sep 17 10:46:23.695: TTY1/12: destroy timer type 10
000602: *Sep 17 10:46:23.695: TTY1/12: no timer type 2 to destroy
000603: *Sep 17 10:46:23.695: Async1/12: allowing modem_process to continue hangup
000604: *Sep 17 10:46:23.695: TTY1/12: restoring DTR
000605: *Sep 17 10:46:23.695: Modem 1/12 ACF: CMD Character mode active
000606: *Sep 17 10:46:23.695: Modem 1/12 ACF: CMD DTR set high
000607: *Sep 17 10:46:23.695: Modem 1/12 ACF: State: Endcall
000608: *Sep 17 10:46:23.695: TTY1/12: autoconfigure probe started
000609: *Sep 17 10:46:23.831: Modem 1/12 ACF: Event: ENDCALL: Disconnect Received
000610: *Sep 17 10:46:23.831: Modem 1/12 ACF: State: Init
000611: *Sep 17 10:46:25.199: Modem 1/12 ACF: State: Idle
000612: *Sep 17 10:46:25.695: %LINK-3-UPDOWN: Interface Async1/12, changed state to down
RDCCI_2ND_HQ#
RDCCI_2ND_HQ#
000613: *Sep 17 10:48:25.695: TTY0: timer type 1 expired
000614: *Sep 17 10:48:25.695: TTY0:  Exec timer (continued)
Please try to help me out in this problem
Rick Morris
Level 6
Level 6
check the configuration whether it is correct or not ,is there any commands are missing
i cann't input the command in line mode
Router(config-line)#autoselect ppp
%Autoselect w/o the interface command 'Async mode interactive' is useless
check the commands and output of the debug
aaa new-model
encapsulation ppp
line aux 0
stopbits 1
line 1/0 1/15
modem Dialin
autoselect ppp
Ronald Garcia
How can I view in a router the lines available to work as modems?
How did you do to know that you can configure:
Thanks a lot
