Unable to connect via ssh to my ISR C921-4P
iewhf02i
I tried to configure the ssh on my c921-4p, I generated 1024 bit keys. Now when I try to connect using this,
ssh cisco@10.0.0.254
I get this error on my Mac OS terminal
Unable to negotiate with 10.0.0.254 port 22: no matching key exchange method found. Their offer: diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
On my IOS terminal this is the output,
*May 21 18:50:12.767: %SSH-3-NO_MATCH: No matching kex algorithm found: client curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c server diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
I tried this method here https://community.cisco.com/t5/switching/logging-ssh-3-no-match-no-matching-cipher-found-client-aes128/td-p/3690528 and added the following line to the config terminal,
ip ssh server algorithm encryption aes128-cbc 3des-cbc aes192-cbc aes256-cbc aes128-ctr aes192-ctr aes256-ctr
I tried the method described here https://community.cisco.com/t5/network-management/open-ssh/td-p/3930558 and I used the following commands
ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 -c aes128-ctr -l cisco 10.0.0.254
ssh -oKexAlgorithms=+diffie-hellman-group14-sha1 -c aes128-ctr -l cisco 10.0.0.254
ssh -oKexAlgorithms=+diffie-hellman-group16-sha1 -c aes128-ctr -l cisco 10.0.0.254
I got these errors on my Mac OS terminal,
Unable to negotiate with 10.0.0.254 port 22: no matching host key type found. Their offer: ssh-rsa
Unsupported KEX algorithm "diffie-hellman-group16-sha1"
command-line line 0: Bad SSH2 KexAlgorithms '+diffie-hellman-group16-sha1'.
And I got these errors on my IOS,
*May 21 19:20:12.711: %SSH-3-NO_MATCH: No matching kex algorithm found: client sntrup761x25519-sha512@openssh.com,curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group1-sha1,ext-info-c server diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
*May 21 19:22:22.051: %SSH-3-NO_MATCH: No matching kex algorithm found: client sntrup761x25519-sha512@openssh.com,curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group1-sha1,ext-info-c server diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
*May 21 19:22:42.305: %SSH-3-NO_MATCH: No matching hostkey algorithm found: client ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-ed25519,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,rsa-sha2-512,rsa-sha2-256 server ssh-rsa
Not sure what's wrong or how I can fix it. What should I do? I have no idea what's going on.
OK @iewhf02i
As concerned this output:
Is it possible to add option on your MAC
ssh -o HostKeyAlgorithms +ssh-rsa .....
Best regards
12 Replies 12
Dh group is different DH14 and DH16.
I have added more error messages, I am not sure what you mean by this.
M02@rt37
Hello @iewhf02i,
Do you try to regenerate the RSA key pairs on the Router: with modulus 2048 ?
Best regards
M02@rt37 I used
crypto key zeroize rsa to remove the keys and I have tried modulus 1024, 2048 and 4096. I still get the same error messages.
OK @iewhf02i
Best regards
M02@rt37 that did it, the command is,
ssh cisco@10.0.0.254 -oKexAlgorithms=diffie-hellman-group14-sha1 -oHostKeyAlgorithms=ssh-rsa
Thanks so much!
Is there anyway I can modify the IOS config or switch to a newer encryption Algo so that I can enter with a simple ssh cisco@10.0.0.254 ?
You're welcome @iewhf02i
Updating the IOS version can help resolve compatibility issues and provide support for newer algorithms.
Do you have this command on your router?
Best regards
Under that command ip ssh server algorithm ? I get 6 options.
Under authentication -> keyboard password publickey
Under encryption -> 3des-cbc aes128-cbc aes128-ctr aes192-cbc aes192-ctr aes256-cbc aes256-ctr
Under hostkey -> ssh-rsa x509v3-ssh-rsa
Under kex -> diffie-hellman-group-exchange-sha1 diffie-hellman-group14-sha1
Under mac -> hmac-sha1 hmac-sha1-96 hmac-sha2-256 hmac-sha2-512
Under publickey -> ssh-rsa x509v3-ssh-rsa
I just managed to get the latest IOS image I haven't figured out how to backup and upgrade it yet.
ssh cisco@10.0.0.254 -oKexAlgorithms=diffie-hellman-group14-sha1 -oHostKeyAlgorithms=ssh-rsa <<- this work
So, the remove any other hostkey and publickey propose by the router and try
I upgraded to the latest IOS version that just came out earlier this year, the algorithms are exactly the same, is there anything else I can do?
how to update the vios i am using gns3 for lab purposes and trying to connect to the cisco iosv router via unbuntu 22 version it says the same the keys were not matching
the above command works fine from connecting ubuntu host to cisco router is gns3 which is running with the vios
Thank you
