unable to delete ip host-routing WS-C2960X-48TS-L
Ranjan Singh
I have Cisco  WS-C2960X-48TS-L and I want to delete/Disable IP host-routing but I failed.
Once I do no ip host-routing in global mode, it removes but i lost Management IP Reachability of Switch and then I will have to apply this ip host-routing again.
I rebooted Switch after No ip host-routing but all goes in vain. I have faced this issue in Cisco 2960G but that resolved after reloading switch but in case of WS-C2960X-48TS-L it did not work. Please help.
Pawan Raut
Level 4
Level 4
Can you try this
no ip host-routing
ip default-gateway x.x.x.x
Hello Pawan
Gateway is already defined. Is it mandatory to re-assign gateway after no ip host-routing
No but make sure it is present
Hello Pawan,
Yes it is present.
