Unable to log in to routers remotely
nygenxny123
I am able to log in to my routers from LAN-
However when i vpn, I am unable to get even a response from a branch router. I can log into other routers at different sites. For some reason though, I get no response from the 4 IP addresses configured on the
interfaces for this particular router
I am able to log into a switch that is direclty connected to it-
And i attempt to telnet through that switch, but i get a "password,required but not set" response. I do have username/pw and login local configured on the vty lines.
does this make sense?
guruprasadr
Level 7
Level 7
HI, [PLS RATE if HELPS]
Refer Link below for Help:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_example09186a0080202614.shtml
Kindly check whether you have followed the procedure as said in above link in configuring the password for Telnet Users.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
i have configured
username xxxx privilege 1 password xxxx
enable password xxxx
line vty 0 4
login local
any ideas?
