Unable to ping out from LAN via PIX firewall
sifurobbie
I have the following setup.
host PC (192.168.9.3) -----> gateway (192.168.9.2) ----- Pix E1 (192.168.9.1)/Pix E0 (81.x.x.250) ------ Internet
The 192.168.9.2 gateway is a 3560 switch connected to the PIX. I can ping out to the Internet via IP from the PIX, but not via the host PC (192.168.9.3) on the LAN. PIX and gateway configs below. Am I missing something that's preventing me pinging out to the Internet from the internal LAN? Any advice is appreciated.
Many thanks,
Rob
PIX config
test-cal-pix01# sh run
: Saved
PIX Version 8.0(3)
hostname test-cal-pix01
enable password btf1YD.Vq7mE6vEA encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 81.x.x.250 255.255.255.240
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.9.1 255.255.255.0
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns domain-lookup outside
dns server-group BT_DNS
name-server 194.72.6.57
name-server 194.73.82.242
object-group network LOCAL_LAN
network-object 192.168.9.0 255.255.255.0
object-group service Internet_Services tcp
port-object eq www
port-object eq domain
port-object eq https
port-object eq ftp
port-object eq 8080
access-list ACLOUT extended permit tcp object-group LOCAL_LAN any object-group Internet_Services
access-list ACLOUT extended permit icmp object-group LOCAL_LAN any
access-list ACLOUT extended permit udp object-group LOCAL_LAN any eq domain
access-list ACLIN extended permit icmp any any echo-reply
access-list ACLIN extended permit icmp any any unreachable
access-list ACLIN extended permit icmp any any time-exceeded
pager lines 24
logging enable
logging buffered errors
logging trap notifications
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group ACLIN in interface outside
access-group ACLOUT in interface inside
route outside 0.0.0.0 0.0.0.0 195.x.x.45 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:c570240e1159a0f83d8ad2c67780deb0
: end
Gateway config
Switch#sh run
Building configuration...
Current configuration : 1583 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable password ###########
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
description uplink to Cisco_PIX
switchport access vlan 9
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
interface Vlan9
ip address 192.168.9.2 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.9.1
ip route 192.168.9.0 255.255.255.0 192.168.9.1
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
milan.kulik
Level 10
Level 10
