Unable to reach remote network trough PPTP and LAN to LAN VPN
SatISV
Dear all,
I have a Site to Site VPN configured into a CISCO RV340W model. It works correctly and i am able to reach the remote network.
That remote network is 192.168.30.X.
The local network is 192.168.0.X.
Then, I have configured a PPTP VPN. The IP I get when connecting through PPTP is 192.168.222.x.
From the PPTP VPN I am able to reach the 192.168.0.X, but unable to reach the remote network: 192.168.30.X that shoud be accesible from the site to site VPN, after reaching the cisco router.
Any ideas of what i am doing wrong?
balaji.bandi
You need to add 192.168.222.x.   in Allow ACL site to site vpn. to reach remote site.
BB
Dear BB,
Many thanks for your quick answer.
Just to clarify, the subnet 192.168.222.X, has been created automatically when I enabled the PPTP server.
I have disabled the firewall, so no ACL should be needed. is that right?
In case I am wrong, what is exactly what I have to do? you mean an Access Rule?
Many thanks for your help and patience
I think you need to add the PPTP assigned subnet (192.168.222.x) as a Local Group on the router that serves as PPTP server, and as a remote group on the other side. Scroll down to the 'Local Group Setup' in the document attached.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5513-configure-a-site-to-site-virtual-private-network-vpn-connect.html
Many thanks Georg,
That is already done. Actually it is configured as "any", so I should be able to connect from any subnet.
Unfortunately, from the remote server  I can only ping the main subnet: 192.168.0.X
It seems that It cannot stablish a VPN to both subnets at the same time.
