Unable to remove network statements in OSPF configuration on Nexus switch
Sergey Lisitsin
Good afternoon,
We've got a Nexus 3k switch running OSPF. In the OSPF config section we've got a bunch of network x.x.x.x/yy statements, which we can't delete. We also can't add any new entries, however we can configure the interfaces for OSPF process. Can anyone suggest a way to add/delete network statements.
Nexus code version is
Software
BIOS: version 3.5.0
NXOS: version 7.0(3)I2(2b)
BIOS compile time: 01/25/2016
NXOS image file is: bootflash:///nxos.7.0.3.I2.2b.bin
Cheers,
Sergey.
5 Replies 5
marce1000
 - Can you provide examples ?
 M.
marce1000,
Sure,
feature ospf
router ospf 1
router-id 192.168.10.253
network 10.10.9.33/32 area 0.0.0.1
network 10.10.9.34/32 area 0.0.0.1
network 10.10.9.49/32 area 0.0.0.1
network 172.20.10.252/32 area 0.0.0.1
network 172.31.10.252/32 area 0.0.0.1
network 192.168.10.252/32 area 0.0.0.1
network 192.168.255.2/32 area 0.0.0.1
network 192.168.255.6/32 area 0.0.0.1
default-information originate
redistribute static route-map rm.static-to-ospf
log-adjacency-changes
XXX-3172T-02# conf t
Enter configuration commands, one per line. End with CNTL/Z.
XXX-3172T-02(config)# router ospf 1
XXX-3172T-02(config-router)# no net?
% Invalid command at '^' marker.
OK guys,
It looks like a bug in NXOS. The network command is not shown in the list of available commands, but it is accepted when fully typed in. Strange thing. I have labbed it up in GNS3 and got the desired result.
Thanks to everyone looking at this issue.
balaji.bandi
Can you post the output while removing from router ospf process no network x.x.x.x/yy
BB
check if you have OSPFv3 enabled (which doesn't use network statements under the OSPF process).
Try and enable OSPFv2:
N3K#conf t
N3K(config)#feature ospf
and check if you can remove the network statements...
