Unable to telnet to or from router
Angelo ANELLO
Hi guys,  i am currently having an issue with telnetting to a router on my network.  The router is working fine, and is contactable.  I am trying to telnet to the router from a 192.168.10.xxx subnet
Here's what ive tested so far:
I can ping the router remotely but cannot telnet to the router
If i connect to a device on the same subnet as the router, i can then telnet to the router successfully.
I cannot telnet out of the router to any device on the network including devices on the local subnet
I can ping any device in the network including devices on other subnets from the CLI
Below is an attached copy of the router config.  Can someone please have a look and see if they can identify what they issue might be.
RTR#sh conf
Using 2954 out of 196600 bytes
! Last configuration change at 10:06:01 AEST Mon May 24 2010
! NVRAM config last updated at 15:55:26 AEST Tue May 25 2010
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname   xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
boot-start-marker
boot system flash:c2801-spservicesk9-mz.124-21a.bin
boot-end-marker
logging buffered 16384 debugging
enable secret 5  xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone AEST 10
clock summer-time AEST recurring 1 Sun Oct 2:00 1 Sun Apr 2:00
ip cef
no ip domain lookup
voice-card 0
class-map match-all MATCH-ESX-DR
match access-group name ESX-DR-SERVERS
policy-map LIMIT-ESX-DR
class MATCH-ESX-DR
    police 2000000
interface FastEthernet0/0
ip address 192.168.20.254 255.255.255.0
ip helper-address 192.168.1.200
ip route-cache flow
duplex auto
speed auto
no keepalive
interface FastEthernet0/1
bandwidth 20000
ip address  xxxxxxxxxxxxxxx  xxxxxxxxxxxxxx
ip route-cache flow
speed 100
full-duplex
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
router bgp 65000
no synchronization
bgp default local-preference 200
bgp log-neighbor-changes
network 192.168.20.0
timers bgp 15 45
redistribute connected
redistribute static
neighbor 10.xxx.xxx.xxx remote-as 7474
no auto-summary
ip forward-protocol nd
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 192.168.1.67 9996
no ip http server
no ip http secure-server
ip access-list extended ESX-DR-SERVERS
permit ip 192.168.1.0 0.0.0.255 host 192.168.20.55 time-range BUSINESS-DAY
permit ip 192.168.1.0 0.0.0.255 host 192.168.20.57 time-range BUSINESS-DAY
snmp-server community xxxxsnmp RO
control-plane
banner motd ^CCC
*      ---- Unauthorised Access Prohibited ----      *
*      Your access to this device will be logged     *
^C
line con 0
exec-timeout 20 0
privilege level 15
password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
login
stopbits 1
line aux 0
line vty 0 4
exec-timeout 20 0
privilege level 15
login
transport input telnet
transport output telnet
line vty 5 15
privilege level 15
login
scheduler max-task-time 5000
scheduler allocate 20000 1000
sntp server 192.168.1.252
periodic weekdays 7:00 to 19:00
end
Any help is greatly appreciated
8 Replies 8
Giuseppe Larosa
Hello Angelo,
as no ACL is applied with access-class under line vty configuration there is no limitation to telnet to or from on the device itself.
A telnet session is a TCP session on port 23 server side.
The problem can be caused by the network around your device if:
- asymmetric routing is happening
- a stateful firewall in on one the possible paths and it sees only one direction of the connection attempt
to understand if this applies you should perform traceroute from both sides to understand if multiple paths exist
I mean from the affected router in DR site and from main site or whatever place you would like to be able to connect to/from
Another possible check is to see if you have applied security features like CBAC on the WAN interface this might explain why you can telnet from "inside" as you have noted.
what if you try to telnet to the ip address on the internal IP subnet from remote?
Have you tested this?
sorry for the basic question
Hope to help
Giuseppe
Thanks for your reply Giuseppe.
I can tracert to the LAN interface from a different subnet to the router.  e.g.  tracert from .10.xxx subnet to the router .20.xxx subnet
When i try to telnet from the same computer on subnet .10 in a remote location, i am unsuccessful.  if i logon to a server in the same subnet as the router, i can telnet successfully.
could there be a restriction to telnet to this device on another router or firewall?
no ip domain lookup - this is the only router with this setting whereas the other routers have ip domain lookup domain name.  Could it be that the router cannot traverse across the network due to not having the domain identified?
None of the other routers on the network have this issue and it has been since its inclusion.
Your feedback is appreciated
Grazie
no ip domain-lookup will prevent the router from doing DNS requests and it would only be a problem on the device your are telnetting from if you were specifying a name instead of IP address but in this case you would have to configure a dns server or hosts entries in the router.
Regards.
Alain.
Hello Angelo,
as Alain has correctly noted no ip domain-lookup influences the capability of the router to use a DNS server to resolve an hostname so it has impact only on sessions starting from the router to other device when using hostname instead of remote device IP address
it shouldn't have an effect on the capability of opening a telnet/ssh session to the device itself
Hope to help
Giuseppe
Thanks to all for your replies.
so just to confirm, after looking at the above config, there should be no reason stopping the ability to telnet to this device from a subnet other than the one the interface resides on?
if not, i will try a reboot.
Do you have a username and password configured?
It may help
Eugen
Lawmaker121
Sounds like Firewall problem blocking ports.
turns out that the subnet mask was wrong on the WAN interface and therefore was not contactable.  once changed it is now contactable.
