Understanding MTU given for GRE tunnel
tommyboay
Hi all,
I have many point to point GRE over IPsec tunnels for my OSPF routing.
I've been working on correcting MSS and MTU values to prevent issues. But something puzzles me :
agde06rtr03#show int tunnel 1
Tunnel1 is up, line protocol is up
  Hardware is Tunnel
  Description: *** blablabla ***
  Internet address is 10.5.4.46/30
  MTU 17916 bytes, BW 50000 Kbit/sec, DLY 50000 usec,
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
Why is that MTU value so high ? What does it represent ?
If anyone can help, thanks much in advance.
Tom
Hello Thomas,
The MTU value in the show interface command was changed in the later IOS versions  The value is calculated based on the platform buffer sizes. So what you are seeing is the maximum value the router can support for a tunnel interface.
A new field, tunnel transport MTU, was added to check the actual MTU value of the interface.
Warm Regards,
Rose
6 Replies 6
Richard Burts
Tom
Would you post the configuration of tunel1? My guess is that something in the configuration is setting the MTU that high. Your post of show interface is a good start. But without seeing exactly what is configured it is hard to give a good answer.
Rick
Rick
Hi Rick,
Here is the complete output :
interface Tunnel1
description *** blablabla ***
dampening
bandwidth 50000
ip address 10.5.4.46 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip pim dense-mode
ip tcp adjust-mss 1360
ip ospf hello-interval 1
ip ospf dead-interval 5
load-interval 30
qos pre-classify
cdp enable
tunnel source GigabitEthernet0/1.606
tunnel destination 10.5.5.77
Hello Thomas,
Warm Regards,
Rose
Rose
Thank you for this very helpful information.
Rick
Rick
Thanks you both for the time you took to answer my question !
Tom
Hi Rose,
Thanks for that info. May I quickly ask  what are the advantages of calculating the MTU based on platform buffers.
Thanks in advance
Kishore
