unequal load balancing sessions for VPDN L2TP not supported on cisco prodect ?
hello guys
is unequal load balancing  sessions for VPDN L2TP not supported on cisco prodect ?
becouse i see only  fail-over and equal loadbalancing on cisco documentation , for example :
for loadbalancing this is the cisco radius attributes :
cisco-avpair  +="vpdn:ip-addresses=1.1.1.1,2.2.2.2",
and for failover :
cisco-avpair  +="vpdn:ip-addresses=1.1.1.1/2.2.2.2",
so can anybody help please , i have LAC and 2 LNSs  , and i need to configure unequal load balancing  on my lac  ,
for example 75 % of l2tp sessions on LNS1 and 25 % of sessions on LNS2,
thank you .
Hitesh Vinzoda
Level 4
Level 4
Hi there,
If you are using this scenario for end users traversing through LAC & LNS, then you can create groups in RADIUS
GROUP01 =LNS01 PRIMARY
GROUP02=LNS02 PRIMARY
Then map your 30 users to GROUP02 and 70 users to GROUP01
then tie your radius tunnel attributes to the groups.
Hitesh
