Unrecognized cookie format for card
Live2 Bicycle
Level 3
Level 3
Trying to save money I ordered a cisco1841 router with out any T1 wic cards since the 1841 was replacing two 1602 routers that already had wic 1dsu t1 cards. When I boot the 1841 router I get the following erroe:
*Aug 26 16:14:11.831: %CFG-3-CARD_NOT_SUPPORTED: Slot 0: Unrecognized cookie format for card!
*Aug 26 16:14:11.871: %CFG-3-CARD_NOT_SUPPORTED: Slot 1: Unrecognized cookie format for card!
When I do a show Diag I get:
WIC/HWIC Slot 0:
FT1 BT8360
WIC module not supported/disabled in this slot
Hardware revision 1.3 Board revision A0
Serial number 12829590 Part number 800-03279-03
FRU Part Number WIC-1DSU-T1=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
EEPROM contents (hex):
0x20: 02 11 01 03 00 C3 C3 96 50 0C CF 03 00 00 00 00
0x30: 50 00 00 00 99 03 05 01 FF FF FF FF FF FF FF FF
WIC/HWIC Slot 1:
FT1 BT8360
Hardware revision 1.3 Board revision B0
Serial number 23258102 Part number 800-03279-04
0x20: 02 11 01 03 01 62 E3 F6 50 0C CF 04 00 00 00 00
0x30: 58 00 00 00 11 09 28 01 FF FF FF FF FF FF FF FF
I think these cards are not compatable and I will need the version 2 cards but I wanted to get a 2nd opinion.
sushilk
The card you are trying to use is not supported on ISR rouetrs.
You need to go with WIC-1DSU-T1-V2 card as these are the cards that are supported on ISR routers.
Sushil
