Updrading ios on 6509-E
sonyscaria
we are upgrading the ios on WS-C6509-E, where we are loading the ios to a disk due to flash size limitation.
RSSW02#dir disk0:
Directory of disk0:/
No files in directory
510631936 bytes total (510631936 bytes free)
But what will be the new path be? i do not see any option for disk0:
RSSW02(config)#boot system ?
WORD TFTP filename or URL
flash Boot from flash memory
ftp Boot from a server via ftp
mop Boot from a Decnet MOP server
rcp Boot from a server via rcp
tftp Boot from a tftp server
RSSW02(config)#boot system flash ?
WORD System image filename
<cr>
7 Replies 7
geo_smith_jr
boot system flash disk0:
Thanks for the reply.But i do not see any option disk0 after flash.
Hi there,
This line will boot from flash, as mentioned in the above post. However you can add the exact file you want to boot.
boot system disk0:the_ios_file_you_have_saved_to_disk0.bin
example may be:
boot system disk0:s72033-ipservicesk9-vz.122-18.SXF11.bin
Good luck with it!
again confused...
boot system disk0:s72033-ipservicesk9-vz.122-18.SXF11.bin or boot system flash disk0:s72033-ipservicesk9-vz.122-18.SXF11.bin
Sorry mate, just saw what I wrote.
You aren't storing the ios in the flash memory, you're storing it on the disk0 memory, so you tell the device to boot from that memory.
boot system disk0:blah_blah.bin
eg
Brad
Thanks bmcginn.
If you refer my first post, you see no option of disk0: after system, like below.
RSSW02#dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
bootflash: Directory or file name
const_nvram: Directory or file name
cwan1/0-disk0: Directory or file name
cwan1/1-disk0: Directory or file name
disk1: Directory or file name
null: Directory or file name
sup-bootflash: Directory or file name
sup-image: Directory or file name
sup-microcode: Directory or file name
system: Directory or file name
In disk0: i have 500mb free space.
RSSW02#dir disk0:
Hi there again,
As you have pointed out, you have no ios on your disk0. You'll need to put the ios on it so when you add the boot system disk0:aldkfjslkdfjasldj.bin command it will reference it.
to save the ios to it, you can use tftp etc.
copy tftp disk0:
That help?
Brad
PS. Note that the disk0 memory area does not show up as an option in the boot system command. (well it doesn't on the 6500's I look after anyway)
