Upgrade IOS Cisco 7204VXR
jomassanell
I'm trying to upgrade IOS in Cisco 7204VXR.
Actually, it's working c7200-ik9s-mz.123-5a. I've tried to upgrade to c7200-ik9s-mz.124-23, and I've change boot system to disk2:c7200-ik9s-mz.124-23.bin, and other IOS, but everytime I restart the router, 7204VXR start with old IOS.
Also, I'm tried to delete old IOS, but router cannot load any new IOS.
Can you help me?
Thank you,
7 Replies 7
Kerem Gursu
Hi ,
After putting the line
boot system flash disk2:c7200-ik9s-mz.124-23.bin , did you erase the old configuration line pointing the old image which is above ?
HTH,
Kerem
Joan
To follow up the good suggestion from Kerem, it might help us figure out what is the issue if you would post the output of show run | include boot
Rick
Rick
Everytime I upload a new IOS, I execute:
- no boot system
- boot system flash disk2:ios
Router#dir disk2:
Directory of disk2:/
1 -rw- 28776396 Aug 31 2004 15:25:28 +00:00 c7200-ik9s-mz.124-23.bin
2 -rw- 18613056 Aug 31 2004 15:27:36 +00:00 c7200-ik9s-mz.123-5a.bin
128030720 bytes total (80640000 bytes free)
Router#sh bootvar
BOOT variable = c7200-ik9s-mz.124-23.bin,1;
CONFIG_FILE variable =
BOOTLDR variable = bootflash:c7200-kboot-mz.123-5.bin
Joan
This information is helpful. It does show that the new IOS is on disk2 and that the boot variable is set to the new IOS. If it is not booting the new IOS there must still be some issue. Perhaps there is some issue with the new IOS at boot time. It would be helpful if you would post all the messages sent to the console during the boot process.
Rick
Rick
I attach console output. Remark that actually i'm tried to execute the new IOS by means of boot system flash c7200-ik9s-mz.124-23.bin, but I've tried to execute boot system flash disk2:c7200-ik9s-mz.124-23.bin and the output is the same.
Joan
Thank you for posting the console messages. It does not show any error that would explain why the new IOS does not boot. If you do show flash, do you see the new IOS in flash? If so then boot system flash should work. If not then please configure with boot system disk2, reload and post the console messages.
Rick
Rick
Is not possible configure either boot system disk2, neither can execute sh flash: or dir flash:
I tried to enter in rommon mode, and console output shows this message when I push Ctrl+Pause:
*** TLB (Load/Fetch) Exception ***
Access address = 0x0
PC = 0x00000000, SP = 0x80005d98, RA = 0x00000000
Cause Reg = 0x00000008, Status Reg = 0x3040d003
ROM Monitor Can Not Recover From Exception
A Board Reset Is Issued
*** Software NMI ***
PC = 0xbfc23680, SP = 0x80005c08, RA = 0xbfc104ac
Cause Reg = 0x00008008, Status Reg = 0x3048d007
CPU Registers:
ZERO = 0x00000000, AT = 0x00020000, V0 = 0xbe840300, V1 = 0xa0000000
A0 = 0xbfc27a10, A1 = 0x0000000d, A2 = 0x80005c0c, A3 = 0x00000000
T0 = 0x54079b83, T1 = 0x00000000, T2 = 0x00000000, T3 = 0x00000000
T4 = 0xd007ffe0, T5 = 0x00000000, T6 = 0xc9800500, T7 = 0xc9800500
S0 = 0x00000000, S1 = 0x80005c60, S2 = 0xbfc27840, S3 = 0x00000009
S4 = 0x80005e70, S5 = 0x00000002, S6 = 0xbfc2f224, S7 = 0x00000003
T8 = 0x3040d001, T9 = 0x00000000, K0 = , K1 =
GP = 0x63005428, SP = 0x80005c08, S8 = 0x00002102, RA = 0xbfc104ac
SREG = 0x3048d007, BADVADDR = 0x00000000, CAUSE = 0x00008008
EPC = 0x00000000, ERR_EPC = 0xbfc23680
System Return Info:
count: 19, reason: user reload
pc:0x607e0ef0, error address: 0x0
Stack Trace:
FP: 0x6412f1b8, PC: 0x607e0ef0
FP: 0x6412f1b8, PC: 0x607c5b9c
FP: 0x6412f1d0, PC: 0x607e6ef8
FP: 0x6412f270, PC: 0x60730120
FP: 0x6412f390, PC: 0x6071d97c
FP: 0x6412f3f0, PC: 0x6072ee24
FP: 0x6412f480, PC: 0x607aa320
FP: 0x6412f498, PC: 0x607aa304
Then, it restarts newly in normal mode.
