upgrade to a NP-225 to NPE-G2
saugatobanerjee
I am planning for upgrade to a NP-225 to NPE-G2 on 7204 VXR router.I have also got 1 GB memory module.Can you pls guide me how to go about it in simple way.
I am also not planning to remove the I/O controller card.
spremkumar
Level 9
Level 9
Hi Saugato
You can refer the below link for upgrading your NPE in your Cisco 7200 series router..
http://www.cisco.com/en/US/products/hw/routers/ps341/products_installation_guide_chapter09186a008054eded.html#wp1019694
regds
Hi ,
Thanks for your reply. But can you inform me regarding any stable IOS(as per Cisco it is 12.4(4)XD ) that you may be successfully using which support SSH2 access.
