Upgrading DSP Channels for PRI lines
orbitbahrain
We have two PRI and 4 BRI lines installed in our Cisco 7206. But we are using only 45 channels live in our PRI lines. Now when i tried to increase the time-slot from 15 channels to 30 channels for 1 PRI line, its giving error message. I like to know how many DSP channels/slots will be available in Cisco 7206 Router board. Please find below our router and dsp details.
Error Message:-
Cisco7206Router(config-controller)#pri-group timeslots 1-31
Current dsp resources can support 26 timeslots;need 2 extra dsps to support the requested configuration
Cisco Router 7206:-
cisco 7206VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 23677191
R527x CPU at 262MHz, Implementation 40, Rev 10.0, 2048KB L2 Cache
6 slot VXR midplane, Version 2.0
DSP details:-
Dsp firmware version: 4.1.41
Maximum dsp count: 30
On board dsp count: 30
Jukebox available
Total dsp channels available 60
Total dsp channels allocated 45
Total dsp free channels 15
Querying dsp status......
Vidhu
9 Replies 9
paolo bevilacqua
Hi, can you send output of show diag to see which hardware you have.
Please find attached show diag of cisco router 7206.
Vidhu
Do you have dspfarm configured currently ?
Do you have other E1 ports doing voice in the same router ?
This is the DSP FARM config,
dspint DSPfarm1/0
codec high ecan-extended
shut 0,6
We have totally 2 PRI lines,
controller E1 1/0
pri-group timeslots 1-16
controller E1 1/1
rEGARDS
VIDHU
You have two dsps shutdown. Take them out of that condition and if they prove faulty RMA the PA.
How to enable these DSP's. How to make it UP.
Vidhu
No shutdown.
Thanks a lot for your gr8 support. Let me try out this command and get back to you if any issues.
Vidhu
You are welcome. Please remember to rate useful posts with the scrollbox below.
