Bookmark
Subscribe
63449
USERNAME WITH PRIVILEGE 15
estelamathew
Level 2
Level 2
Hello Dear's,
I have created a user with command username cisco privilege 15 password cisco when he telnet to the switch he is asked for the enable secret passwrd why??????
24 Replies 24
Hello Experts
what can be the issue,i m hitting may be IOS issues if i upgrade it will help me ????
Thanks.
Hi Mathew,
I would try a IOS upgrade.
What IOS/hardware are you using ?
Dan
Did you try it like this:
sw-test(config)#
sw-test(config)#user emgi privilege 15 password cisco
sw-test(config)#
sw-test(config)#lin vty 0 4
sw-test(config-line)#login ?
  local   Local password checking
  tacacs  Use tacacs server for password checking
sw-test(config-line)#login local
sw-test(config-line)#^Z
User Access Verification
Username: emgi
Password:
sw-test#sh priv
Current privilege level is 15
sw-test#
System image file is "flash:c2950-i6q4l2-mz.121-22.EA2.bin" (Ancient!)
I have a switch model Cisco Catalyst 3550 48 SMI Switch i have uploaded 12.2.44.SE(6) ED the latest uptill date,  The switch model number is 3550 48 SMI and i have uploaded the IOS 12.2.44.SE(6) EMI The software is uploaded successfully with no errors but still i have same issue,Is it the switch is supported with the above software How i will come to know.
The  Feature Navigator shows me the image as in the attached, but the image is too old,Can anybody confirm me the image ihave installed is perfect.
Hi Estela,
ok... I don't have this particular device but why not try least painful way. If it doesn't break your security policy why not enable aaa like this:
aaa new-model
aaa authentication login VTYLOGIN local
aaa authorization exec VTYLOGIN local
line vty 0 4
login authentication VTYLOGIN
authorization VTYLOGIN
It will solve your problem, OK it doesn't solve original issue... but it will work and you will not see any diference
Tomas
ebarticel
Level 4
Level 4
I think you should add "login local" in vty line config mode.
login local it will point to the username you created
Also when you create the username with level 15 you have to user "secret" instead of password, because you know that when you have configured "enable password" and "enable secret" , the enable secret will be used.
Because you have enable secret configured on the switch/router, it will always ask for the "enable secret".
Eugen
I have login local enable also after upgrading to latest new IOS the issue is same i have been asked for the enable secret for the privilege 15 user.
Hi estela,
Try this commands if you still have the problem:
S(config)#username TELNET priviledge 15 secret cisco
S(config)#line vty 0 15
S(config-line)#login local
S(config-line)#priviledge level 15
S(config-line)#end
Hope this will help
Eugen
Certainly helps, just that all the users authenticating via ssh / line VTY 0 5 or 5 to 15 whatever is activated gets  a privilege 15 access, and is not going to be prompted for enable password.
Test this by adding two new users, with different privileges: 0 and 15, for either or there will be prompt for enable password.
If this is for test purposes this will work, if is not compliant with you policy there should be some more work on aaa  new-mode and radius server if that is something that you use as authentication means.
Although this is a very old thread I will post my answer for the benefit of anyone looking through this.
This post by ebarticel explain the cause of the issue you are having. In your config you have,
enable secret 5 $1$P92y$/qnN50lCrnBAJJgIW1blc0
enable password 7 095B4F1A0D0000131F09160B
username hoswitch password 7 xxxx
username cwlms privilege 15 password 7 xxx
username admin privilege 15 password 7 xxx
So the device will prompt for enable secret.
As sugested use the following syntax,
username username privilege 15 secret password
Eg;
username admin privilege 15 secret cisco
