Using Cisco 887 as a "bridge" Device
javdakker
Is it possible to use a cisco router, in this case a cisco 887, to bridge an external ip address to a device behind the router?
I need this because i only get 1 IP Address from my ISP and i want this IP address on my ASA.
I was thinking of a bridge group, but i'm not sure how to go about it!
I would like to know if this is possible, and if this is, how should i configure it.
                                                    ISP
                                              Router (ATM)
                                       ASA (external ip(NAT))
                                             Local Network
2 Accepted Solutions
John Blakley
I'm not sure if this will work, but give this a shot and let me know:
bridge irb
On your ATM interface, put "bridge-group 1"
On lan interface: bridge-group 1
create a bvi interface with no ip address: "int bvi1"
And the final touches: "bridge 1 protocol ieee"
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Yes, it will work.
7 Replies 7
John Blakley
bridge irb
HTH,
John
Hi John!
Why would i need to create a BVI? And on a lan interface i can not issue bridge-group one, this has to be stated on the VLAN. So this would be more like:
interface ATM0.1
no ip address
no atm ilmi-keepalive
bridge-group 11
pvc 0/33
encapsulation aal5snap
interface FastEthernet0
switchport access vlan 11
no ip address
interface Vlan11
no ip address
bridge-group 11
bridge 11 protocol ieee
And then i would need to do the authentication on the ASA i presume?
I need to test this, not on location right now! Thanks for your input!
My test didn't use a vlan interface. What you have above should work. If it's a pppoe account, your authentication would need to be done on the ASA, but you should get the public address to it like you're wanting.
HTH,
John
Well its a dsl atm connection that means its a pppoa connection. I want to test this configuration with my pc connecting to the interface of the router.
On my pc i can make a pppoe network and use the credentials of the ISP. Would this work or wouldnt it?? As its technically not an pppoe connection...
Yes, it will work.
I know this is an old post, but I'm trying to the exact same thing using a rural ADSL2 connection here in New Zealand with my Cisco Meraki equipment which only handles PPPOE authentication.  I have an old Cisco 897 and I think I understand your configuration, but I'm a little unsure how to configure the encapsulation correctly because NZ Telcos use 0/100 and VC MUX and not SNAP.
In this situation, how would I alter your config for aal5mux? Would I do something like this?
encapsulation aal5mux bridge ieee8023
-or-
encapsulation aal5mux pppoe group global
Or do I need to somehow link it to bridge-group 11 (as show in this config example from the OP)?
javdakker
This has been solved, thanks alo for the input!
