07-13-2020 01:44 AM
Hi Guys,
Is it possible to use Stackwise Virtual technology at Intermediate Node as it is a point of aggregation for access layer and it can still support layer-3 routing.
07-13-2020 03:25 AM
Sure SVL it support Layer 3 routing. Do you see any difficulties, please explian or show us the issue undertstand better.
07-13-2020 03:55 AM
07-13-2020 10:09 AM
Cisco Offer Many solutions. But business need to take decision on based on the below conditions i look.,
1. is the organisation ready to SDA / DNAC ready to deploy
2. how big is the network. ( few or les than 50 devices ?) - so so i would not bother to go with DNAC
3. there is possibility you can deploy SDA with DNAC, but is this really required organisation point of view.
4. If you have any legacy network - you need to consider.
5. if you looking only Core - then i would suggest to go with SVL - or Layer3 depends on your comfort and experience to maintain same.
Sure Cisco moving towards DNAC - what cost ? can the organisation ready to spend ?
07-13-2020 11:20 AM
07-13-2020 12:32 PM
if you like to like a replacement, then use L3 Mode with HSRP, to support your legacy environment.
sure it will be DNAC ready new Cat 9K models.
