Verifying the QOS by Reserving bandwidth to a PC
harisivaji
I need to limit bandwidth or Reserver bandwidth for a network, Eg:Iam having 1Mbps connection and there are two vlans
NetworkA
128 is for Voice
128 for Web
256 for  data
and
Network B
256 for Voice in this network
256 for data in this networkB
.So any network can use only the specified bandwidth as maximum  irrespective of congestion in the network or not.
I thought to use "Bandwidth" command to reserver required bandwidth for each network.But i read in documents that Bandwidth which is specifiedunder this command is used only when there is congestion.
Iam not able to use Rate-limit becuase i need to classify different traffic in NetworkA and reserver BW for each
How i can achieve this?
For testing i configured QOS for a specific PC by reserving only very less Bandwith using Police command but
Download and Upload speed is same Before QOS applied to WAN interface and after QOS applied.(that too speed is maximum)
Iam testing using  Speedtest.net in browser
Is my Testing is Right?
Why iam not getting limited Bw
Hitesh Vinzoda
Level 4
Level 4
try downloading a file from web and limit your PC to use http traffic for x amount of low bandwidth. than try
Hitesh Vinzoda
