11-27-2008
04:39 AM
- last edited on
03-25-2019
03:21 PM
by
ciscomoderator
Please I have some Ques.
1. Is it possible I see the content of a 'copy config tftp' with notepad or any other format.
2.Is there any diff btw 'copy run start' and 'write'.
11-27-2008 05:34 AM
"1. Is it possible I see the content of a 'copy config tftp' with notepad or any other format. "
If you mean after loading config to a Windows PC, yes. However, notepad might not like the CRLF combination, if not, try WordPad.
"2.Is there any diff btw 'copy run start' and 'write'. "
On the later IOS images (12.4), at least for routers, there is. "sh arch conf diff nvram:startup(press tab) system:running(press tab)" (syntax is from memory, it might be incorrect.
11-27-2008 06:19 AM
Thanks greatly. I am so impress.
I am having an issue here. I have a 3800 series router that connects branches. But of recent I noticed the router will lose connection to some branches,even when the ISP confirm that the link is fine. But when I reboot the router,they all come up. I have like 5 ISP on the router. This problem is peculiar to just 1 ISP (A) and the most baffling thing is that its not all the branches that ISP A is supporting that get affected,but part and same branches.
Please what is the problem with the router.
12-01-2008 03:24 AM
Hello Kennie..
Could you tell me what type of connectivity you are using is it E1/T1 connection and if it has been configured as unframed, try to make it to framing of CRC4 and encapsulation as PPP.. I hope it helps. .
Harish
