Vlan-aware MAC-learning on ASR920|IOS-XE
raichmayer
HI,
I do have a problem on and ASR920. I configured two service instances on one physical interface  for different .1q VLANs. Both instances attach the same device into the same bridge-domain. This is intended to be used for two  euqal services from a single CPE. Every instance needs to rewrite the incoming VLAN-TAG.
interface GigabitEthernet0/0/3
 service instance 34 ethernet
  encapsulation dot1q 34
  rewrite ingress tag translate 1-to-1 dot1q 101 symmetric
  bridge-domain 4 split-horizon group 0
 service instance 35 ethernet
  encapsulation dot1q 35
  rewrite ingress tag translate 1-to-1 dot1q 102 symmetric
The problem here is , that the BD seems  to be "NOT VLAN-aware" and learns the MAC from both instances which results in a FlipFlop behaviour and packetloss for one of the instances.
Is it true that the ASR920 can not distinguish between the same MAC-Adr with differen .1q tags int the same bridge-domain.
Thanks & Regards,
Rene
0 Replies 0
