vlan bandwidth monitoring on Cisco 3560 Switch
simonmbizwo
Please kindly assist advise, i wish to monitor bandwidth usage per vlan, on my switch.  I dont seem to be getting OID's for vlans.
Is there a way i can do this as snmp is not able to differentiate traffic per vlan.
2 Accepted Solutions
Dennis Mink
what is it exactly that you want to monitor?   the in/out traffic on a certain SVI?
like for example  interface vlan 10?
SNMP should do this.
cheers
Please remember to rate useful posts, by clicking on the stars below.
OK, but do you want the IN/OUT on the interface vlan X?
7 Replies 7
Dennis Mink
cheers
yes, i want read input and output octets using snmp and then using a script calculate the in/out traffic, producing graphs on nagios.  i have tried with snmp , i dont seem to be getting vlan OIDs.
yes i just want in/out on the interface thats all
These links may help you find some related info.
https://supportforums.cisco.com/discussion/11330386/snmp-oid-current-port-utilization-2960-3560-and-3750-switches
http://tools.cisco.com/ITDIT/MIBS/MainServlet
hth
MS
I have already done this for physical interfaces on the switch ,now i want to do so for vlans. snmp doesnt seem to have a way to differentiate vlan traffic and separate it. If there was an OID for a vlan , it would be easier to read the in/out octets. The links you gave me explain what i have done already.
It's not possible to get information about transit vlans on this platform. You can only get values for Physical / SVI / Port-Channel interfaces.
