Vlan Mapping on Cisco 6800
afsharmilad89
Hello dear colleagues,
Is there any way to configure "switchport vlan mapping default drop" on cisco 6800 interfaces? or any alternative solution for this case? my interface configuration is shown below:
interface TenGigabitEthernet7/28
switchport
switchport vlan mapping enable
switchport vlan mapping 110 32
switchport mode trunk
end
Hello Georg,
Of course the 6800 series support both of mentioned features and it's working fine right now, but my issue was about limiting the number of vlans by using "trunk allowed vlan" command under interface, and I found the solution as well, I didn't permit vlan number 1 so the vlan mapping couldn't work probably, I just added vlan number 1 and now everything is working fine.
switchport
switchport trunk allowed vlan 1,32,110
end
Thanks for your reply
Milad
to my best knowledge neither VLAN mapping nor Q-in-Q are supported at all on the 6800...
Hello Georg,
switchport
end
Milad
Hello Milad,
ouch...my bad, I misunderstood the question, I thought you were looking for the equivalent of the vlan mapping confg on the 6800 (for which I honestly could not find any reference at all). Either way, glad you got it resolved...
Deepak Kumar
Can you check below link:
https://ipcisco.com/vlan-mapping-vlan-translation-%E2%80%93-part-2/
Q-n-Q will helpful to you.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
