Vlans can't talk to the gateway with static nat rule
willmaci
Sorry if this is a long post but i'm racking my brain against the wall here.
I have a strange setup where the building owns the router and they have cables throughout the house and provide us with a switch only. I decided to put a cisco C841M-4X-JSEC/K9 and I'm using a microtik switch so I could add vlans and start setting my network. I'm currently using these VLANs and this gateway IP.
VLAN2: 10.8.8.0/24
VLAN3: 10.8.3.0/24
Gateway IP: 10.150.208.1
The current issue I have is my VLANs can communicate with each other but they cannot ping the gateway. I tried adding a static nat rule coming from one of the VLANs and then i can communicate to the gateway IP without any issue. If anyone could help me I would be extremely grateful
Current config:
version 15.5
hostname home
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp pool 2
network 10.8.8.0 255.255.255.0
default-router 10.8.8.1
dns-server 8.8.8.8
ip dhcp pool 3
network 10.8.3.0 255.255.255.0
dns-server 8.8.8.8
default-router 10.8.3.1
ip dhcp pool 4
network 10.8.4.0 255.255.255.0
default-router 10.8.4.1
dns-server 8.8.8.8
no ip domain lookup
ip domain name home.local
ip cef
no ipv6 cef
redundancy
lldp timer 10
lldp run
no cdp run
interface GigabitEthernet0/0
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
duplex auto
speed auto
interface GigabitEthernet0/4.2
encapsulation dot1Q 2
ip address 10.8.8.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/4.3
encapsulation dot1Q 3
ip address 10.8.3.1 255.255.255.0
interface GigabitEthernet0/4.4
encapsulation dot1Q 4
ip address 10.8.4.1 255.255.255.0
interface GigabitEthernet0/5
ip address dhcp
ip access-group 112 in
no ip redirects
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan2
no ip address
interface Vlan3
no ip address
interface Vlan4
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static 10.8.8.10 10.150.209.111
access-list 2 permit 10.8.0.0 0.0.255.255
line con 0
no modem enable
line vty 0 4
access-class 50 in
exec-timeout 5 0
login
transport input telnet ssh
line vty 5
login
scheduler allocate 20000 1000
end
NOTE:- no static NAT config in router
NOTE:- SW must be L2SW with command "no ip routing"
12 Replies 12
willmaci
And also here is my nat translation table
home#show ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
tcp 10.150.209.111:16817  10.8.8.10:16817       20.198.119.84:443     20.198.119.84:443
tcp 10.150.209.111:16819  10.8.8.10:16819       20.198.118.190:443    20.198.118.190:443
tcp 10.150.209.111:16894  10.8.8.10:16894       172.217.174.106:443   172.217.174.106:443
tcp 10.150.209.111:16945  10.8.8.10:16945       52.36.24.174:443      52.36.24.174:443
tcp 10.150.209.111:16954  10.8.8.10:16954       74.125.247.128:3478   74.125.247.128:3478
tcp 10.150.209.111:17056  10.8.8.10:17056       34.149.211.227:443    34.149.211.227:443
tcp 10.150.209.111:17393  10.8.8.10:17393       172.217.31.131:443    172.217.31.131:443
tcp 10.150.209.111:17423  10.8.8.10:17423       34.120.85.253:443     34.120.85.253:443
Static route need to config to make your topolgy work.
Apologies just for clarification do you mean I would need to do
ip route 0.0.0.0 0.0.0.0 10.150.208.1
Here is a copy of my current route table.
home# show ip route
Gateway of last resort is 10.150.208.1 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 10.150.208.1
10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
C 10.8.3.0/24 is directly connected, GigabitEthernet0/4.3
L 10.8.3.1/32 is directly connected, GigabitEthernet0/4.3
C 10.8.4.0/24 is directly connected, GigabitEthernet0/4.4
L 10.8.4.1/32 is directly connected, GigabitEthernet0/4.4
C 10.8.8.0/24 is directly connected, GigabitEthernet0/4.2
L 10.8.8.1/32 is directly connected, GigabitEthernet0/4.2
C 10.150.208.0/22 is directly connected, GigabitEthernet0/5
L 10.150.209.111/32 is directly connected, GigabitEthernet0/5
home#
Hello
Try the following:
conf t
no ip access-group 112 in
exit
ip nat inside
exit
ip nat inside
exit
no ip nat inside source static 10.8.8.10 10.150.209.111
ip nat inside source list 2 interface GigabitEthernet0/5
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/5 dhcp
Kind Regards
Paul
I tried your config but when I did, all VLANs could not communicate with the default gateway ip of 10.150.208.1
I tested 3 scenarios
VLAN2 > VLAN4  (successful - I could ping the devices and the ip gateway)
tracert -d 10.8.4.2
Tracing route to 10.8.4.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  10.8.8.1
  2     1 ms     1 ms     1 ms  10.8.4.2
Trace complete.
 VLAN4 > VLAN2 (unsuccessful - I could ping the gateway of the VLANs but not any devices or the default gateway IP of 10.150.208.1)
ping 10.8.8.1
Pinging 10.8.8.1 with 32 bytes of data:
Reply from 10.8.8.1: bytes=32 time<1ms TTL=255
ping 10.8.8.10
Pinging 10.8.8.10 with 32 bytes of data:
Request timed out.
VLAN ANY > Defaul Gateway (unsuccessful - before your config suggestion I could  get to the internet from VLAN2 but after the change I can't ping the default gateway IP)
tracert -d 10.150.208.1
Tracing route to 10.150.208.1 over a maximum of 30 hops
  2     *        *        *     Request timed out.
tracert -d 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
that great detail,
issue is because both VLAN have same GW !!
you need to config each VLAN with different GW.
I was looking through documentation but my apologies, I couldn't find anything on configuring a different GW per VLAN
So I believe there are 2 issues.
1. Vlan communication is only one way for some reason.
10.8.8.10 (PC1) >> 10.8.8.1 (Router gi0/4.4) >> 10.8.4.2 (PC2)
tracert -d 10.8.4.2
10.8.4.2 (PC2) >> 10.8.4.1 (Router gi0/4.2) XX 10.8.8.10 (PC1)
# traceroute 10.8.8.10
traceroute to 10.8.8.10 (10.8.8.10), 30 hops max, 60 byte packets
1  _gateway (10.8.4.1)  1.757 ms  1.602 ms  1.693 ms
2  * * *
3  * * *
2.  However if I make a static nat statement per IP then each vlan can communicate to the internet and also to the other VLANs Like so
The network that connects me to the internet is 10.150.208.0/22
ip nat inside source static 10.8.4.2 10.150.209.44
ip nat inside source static 10.8.8.2 10.150.209.49
ip nat inside source static 10.8.3.2 10.150.209.58
Then I can get to the internet via the gateway ip 10.150.208.1 and the other VLANs
traceroute to 10.8.8.1 (10.8.8.1), 30 hops max, 60 byte packets
1  _gateway (10.8.3.1)  12.084 ms * *
traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1  _gateway (10.8.3.1)  2.497 ms  2.452 ms  2.518 ms
2  10.150.208.1 (10.150.208.1)  2.580 ms  2.609 ms  2.640 ms
3  192.168.200.5 (192.168.200.5)  8.997 ms  9.340 ms  9.776 ms
However after a little bit of time, I do lose connectivity to the internet.
share last config I will correct it with some note
! Last configuration change at 12:24:01 UTC Mon Oct 31 2022
version 15.5
hostname home
boot-start-marker
boot-end-marker
enable secret 5 $1$VSe6$w5JRTNqyERV1qCqkXU80Q/
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 10.8.8.1
ip dhcp excluded-address 10.8.2.1
ip dhcp excluded-address 10.8.3.1
ip dhcp excluded-address 10.8.4.1
ip dhcp pool 2
 dns-server 8.8.8.8
ip dhcp pool 4
 dns-server 8.8.8.8
ip dhcp pool 3
 domain-name 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
license udi pid C841M-4X-JSEC/K9 sn FGL2109212W
redundancy
lldp timer 10
lldp run
no cdp run
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 duplex auto
 speed auto
 ip nat inside
 ip nat inside
 ip nat inside
 ip address dhcp
 no ip redirects
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan2
 no ip address
interface Vlan3
 no ip address
interface Vlan4
 no ip address
no ip http server
ip nat inside source list 2 interface GigabitEthernet0/5 overload
ip nat inside source static 10.8.3.2 10.150.208.125
ip route 10.8.4.0 255.255.255.0 GigabitEthernet0/5
line con 0
 no modem enable
line vty 0 5
 exec-timeout 5 0
 login
end
I also tried doing these commands from above but I wasn't able to connect to the internet from any vlan after I tried them
I forgot to put in the wildcard bits. Once I did, your config worked perfectly. Thank you so much for this! I marked it as the correct answer. For the sake of anyone having trouble with this same thing, I am leaving the config in here.
Here was my final config
@paul driver @MHM Cisco World Thank you both so much for your help. Couldn't have done it without either of you! Good luck to both of you
hostname home
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp pool 2
 dns-server 8.8.8.8
ip dhcp pool 4
 dns-server 8.8.8.8
ip dhcp pool 3
 domain-name 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
redundancy
lldp timer 10
lldp run
no cdp run
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 duplex auto
 speed auto
 no routing dynamic
 ip nat inside
 ip nat inside
 ip nat inside
 ip address dhcp
 no ip redirects
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan2
 no ip address
interface Vlan3
 no ip address
interface Vlan4
 no ip address
no ip http server
ip nat inside source list 10 interface GigabitEthernet0/5 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/5 10.150.208.1
access-list 10 permit 10.8.4.0 0.0.0.255
access-list 10 permit 10.8.8.0 0.0.0.255
line con 0
 no modem enable
line vty 0 5
 exec-timeout 5 0
 login
end
You are so so welcome
